R50/53 Defrost blower level adjustment?
Old Apr 17, 2013 | 07:41 PM
Brianjager's Avatar
Brianjager
'05 R50
The blower motor always defaults to high (level8) when defrost is chosen on the climate control module. I did some digging (http://www.bmw-planet.com/lib/mini/HVAC%20OVERVIEW.pdf) and found that this is default.
Was wondering if anyone has been able to mod this to have an adjustable blower on defrost?
Old Apr 17, 2013 | 09:36 PM
Eric_Rowland's Avatar
Eric_Rowland
If you press and hold the defrost button, it goes into 'non jet engine blower' mode which is effective and much more tolerable.
Old Apr 18, 2013 | 05:20 AM
scf's Avatar
scf
THANK YOU!
This has driven me nuts for some time now, just kept forgetting to ask questions about it. Sweet!
Old Apr 18, 2013 | 11:13 PM
AlexQS's Avatar
AlexQS
I have had my MINI for a week, so I'm learning things too. I tried today, but mine doesn't do that when I press and hold the defrost button. Pressing and holding, or one quick press always does the same thing, either turns it on high or turns it off.
BTW Mines an '05 MCS with auto climate control.
Anywho, the solution I found works, but requires more button presses. Press the Up Arrow (opens the defroster vent) press the Minus Button as needed (turns down the fan speed), press the rear window defrost button if needed, and don't forget that defrost will work best when a/c is on -the temp does not need to be set cold, but having it run behind the heater acts as a dehumidifier.
Is my defrost button programmed wrong?? I noticed that I can not open or close windows with the key fob either, and I believe that is a programming issue.
Alex
Old Apr 19, 2013 | 06:11 AM
ZippyNH's Avatar
ZippyNH
Heat/ac same as mine.
keyfob programming was a customer option...buttons could do different things. The range is quite short, but many folks had issues with the keys getting buttons pressed in pants/purses....and sunroof /windows opening ....if rain happens...ouch. many had the feature unprogrammed.
Old Apr 19, 2013 | 02:51 PM
Brianjager's Avatar
Brianjager
Eric Rowland, this worked amazingly!
Old Apr 19, 2013 | 03:32 PM
Eric_Rowland
Glad I could help. Hopefully all will remember when winter comes around again.
vetsvette
Oct 11, 2015 06:05 PM
Oct 1, 2015 12:13 PM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
Emnotek
Sep 29, 2015 07:37 AM
