R50/53 Best rear lower control arms?
Old Apr 17, 2013 | 03:34 PM
christianmc's Avatar
christianmc
Hi all, the rear tire on my Mini has started to develop choppiness. I replaced the front lower control arms last year with polyurethane ones, but I never did anything to the rear. My car is not lowered at all.
My mechanic said sometimes it's possible to correct this with an alignment, but instead of wasting time in case it can't be done, he suggested I buy some rear lower control arms. As I plan at some point to lower my car a little, I think this is a good idea.
My mechanic suggested the Megan ones as good and cheap. I notice on Way's site several options:
http://www.waymotorworks.com/02-06-c...pension/links/
Megans are $200. But I see NM engineering has a pair for $170. I'm not interested in skimping out on quality to save a few bucks, but is there any reason to get the more expensive ones? And Does anyone have experience with those NM engineering ones? Thanks!
Old Apr 20, 2013 | 07:20 PM
christianmc
bump. Also what about the KAVS one for $130?
http://www.ebay.com/itm/KAVS-Motorsport-rear-control-arms-MINI-Cooper-01-12-rear-toe-link-kit-JCW-BMW-/260918919972?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cbffac324&vxp=mtr
Seems like a good deal, is there any reason to get the more expensive, $200 + brands? Thanks.
Christian
Old Apr 22, 2013 | 08:42 AM
OldGameFreaK's Avatar
OldGameFreaK
I use the ones from this guy http://stores.ebay.com/MCSpecial-Min...pension?_rdc=1
He ships fast and makes a great product.
Old Apr 22, 2013 | 09:03 AM
jasonsmf's Avatar
jasonsmf
Before spending $ on the control arms to adjust camber, I'd really look at having the toe-in adjusted (this is adjustable from the factory without having to replace parts). Many MINI's are running around with too much rear toe-in which causes excessive tire wear more so than camber does.
Jason
Old Apr 22, 2013 | 03:57 PM
christianmc
Thanks for the responses! OldGameFreak, does that guy make all of those rear control arms? Which one did you get and how would you compare it to the other ones on the market? Are there any advantages/disadvantages?
jasonsmf, thanks for the tip. I don't know what the toe-in is, so I'm probably not qualified to adjust the toe-in on my own. But I do notice that the right rear wheel that's giving me the problem does have noticeably more camber than the other wheel for some reason, even though my car is not lowered at all. I just noticed it recently, and I'm not sure why I didn't see it before. Also, as I'm planning on lowering the car eventually, I'm probably going to go ahead with the rear-control arms.
FWI, my goal is to get the ST coilovers. Not sure if that should affect what kind of rear control arms I should invest in now.
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
wkp1219
Nov 13, 2015 07:52 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
