Suspension Coilover sleaves
Old Apr 17, 2013 | 01:00 AM
esfreerider's Avatar
esfreerider
Coilover sleaves
I plan on running swift spec R's with Koni sports and I'm hoping that coilover sleeves like the ones on summit would work with this application.
http://www.summitracing.com/search/p...l-over-sleeves
Old Apr 18, 2013 | 03:31 AM
blue2turbo's Avatar
blue2turbo
No going to work unless you plan on having custom perches built onto the Koni's. Then you'd also have to find a new plan for an upper mount as well. Only other option would be to have the bodies of the koni shock threaded so that the coilover sleeves can be screwed onto the Koni insert. I know some people in the MR2 world that did this for Autocrossing.
I'm 99% sure you will void the warranty through Koni and if you're going to go custom route like that, you're not going to be able to run Swift Spec R's, you'll have to run regular Swift Metric Coilover springs. Spec R's are shaped and built to work in the stock spring perches and upper mounts.
What would your goal be? to have the Koni/Swift R setup and be able to adjust height?
Old Apr 20, 2013 | 10:36 AM
esfreerider
Yes my goal was to do the koni/swift combo and have adjustable ride height but id be happy if with that combo I sat about 0.5ish inches lower.
Old Apr 20, 2013 | 10:37 AM
esfreerider
I'm not worried about warranty voiding btw.
RIchard Nguyen
Sep 14, 2016 11:43 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
sssevita
Mar 20, 2016 06:24 AM
CooperSharp
Oct 12, 2015 09:21 AM
gnhovis
Sep 28, 2015 10:56 AM
