R50/53 problems with start-ups :(
Old Apr 11, 2013 | 01:19 PM
Boosty's Avatar
Boosty
So for the past two days now I've been having really jerky starts, weather It's a cold start or not
I turn the key the car starts like normal however as soon as the engine runs I feel a jerk motion, if i idle and press the accelerator the car gets the jerk motion still except It's not as bad as on start up
It doesn't feel like a misfire to me , honestly it feels like the crank isn't lubed enough..so today I may get an oil change, last night I used some fuel injection cleaner and re fueled. It helped but only slightly
Any opinons ?
Old Apr 11, 2013 | 01:26 PM
buzzsaw's Avatar
buzzsaw
https://www.northamericanmotoring.co...-starting.html
Old Apr 11, 2013 | 02:43 PM
Boosty's Avatar
Boosty
The link isn't loading:/ but judging by the address of the link
I can tell you my car isn't stalling , I have no fault codes , I also have no idiot lights Illuminated ,
While sitting in traffic today i noticed very slight jerking(possible misfires)
Checked the oil and It's a little dark but the levels are fine
On my crossfire I had a similar issue and it was the cam position sensor failing
Old Apr 11, 2013 | 04:20 PM
Boosty's Avatar
Boosty
Link worked , from What I read could be coil packs and wires needed to be replaced, fuel pump and filter , worn pcv or ecu issue.
However before going ahead and making an appointment with MINI anything I should take note of?
A lot of people posted that the dealerships will want to begin diagnosing with ignition systems first ..but can some one tell me What model years the "upgraded" ecu issue affected ? I haven't checked the build date on my mini yet
UncDeo
Nov 4, 2019 04:08 AM
tylewis
Sep 6, 2015 01:07 PM
mikeandtricie
Sep 4, 2015 01:42 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 2, 2015 09:05 AM
