R52 Help with Finding Screw
Old Apr 10, 2013 | 04:36 PM
woodstudio's Avatar
woodstudio
I have a 2005 R52 cabrio. I'm looking to replace screws that are at the bottom of the convertible top where it meets the rear boot door. They are torx style M20 and measure 18 mm long. They hold the weatherstripping and center rear brake light in place. Any ideas of what the part number is? A photo is below. THANKS
Old Apr 10, 2013 | 06:11 PM
ZippyNH's Avatar
ZippyNH
if you want OEM ones...
Go to realoem.com
enter your production date...and go to the diagrams of the area of the car you are working on...
it will show a schematic...and include part's for all scews, etc, along with a "suggested" price.
Old Apr 10, 2013 | 06:33 PM
Braminator's Avatar
Braminator
You can take it to Lowes as they have a metric screw and bolt section. They might have it.
Old Apr 10, 2013 | 09:01 PM
rkw's Avatar
rkw
Show a picture of where they go on the car. If there are 4 of them, it may be part # 51131879479 from the dealer.
http://realoem.com/bmw/showparts.do?...72&hg=63&fg=25
Old Apr 11, 2013 | 10:09 PM
Fly'n Brick's Avatar
Fly'n Brick
AutoZone can also identify and replace metric metal fasteners if that is easier to find.
Old Apr 12, 2013 | 10:26 AM
Looks like its not separate but part of one of the trim install kits( seperate from convertible trim kit ). The larger side screw #24, near the front side does not look like it either.
It looks like the screws that go a the way across the trim and insert into the holes that mount these to the bottom of the convertible top.
Convertible Top Rear Trunk Molding Kit
http://www.ecstuning.com/Search/51137123437/ES2602375/
" it may be part # 51131879479 from the dealer " Looks like this and has a Phillips head.
Thanks and hope that helps.
Old Oct 29, 2013 | 08:51 AM
Woodstudio - Good news , we found the hardware people have been looking for on the R52 MINI Convertible and have included with our rear trim install kit.
These will be back in stock soon.
https://www.northamericanmotoring.co...lding-kit.html
We also have it on its own , just for people who have repaired the trim and need just the hardware. The pop rivets are included in the kit from MINI , but they are there for a little bigger repair, the trims use all but the pop rivets.
Mounting Trim Kit Part # 54347162754
http://www.ecstuning.com/Search/SiteSearch/54347162754/ES158808/
Thanks and I hope that helps some people.
Mib4840
Oct 22, 2019 08:16 PM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
eliseo1981
Aug 6, 2015 05:00 AM
