Key fob or serious issue?
Old Apr 4, 2013 | 08:38 PM
mimaal's Avatar
mimaal
I recently bought a 2007 Mini used with 62k miles on it. Everything seemed fine except the key.
I'm 'lucky' enough to have one of the keyless-but-not-really remote keys.
Originally the fob just wouldn't eject from the slot with out some serious jiggling and pushing. Then it wouldn't eject at all, or would eject but leave the car still running. Eventually i just resorted to pulling the key out and turning it off with the button.
Now it's decided to give me a wondrous new problem where putting the key in does nothing at all. i can jiggle it, push it, anything, but it will not light up my dash or turn on the radio.
It's not the battery in the car, because i can manually turn on the radio and such, and it's not the key battery because i can still unlock/lock my car and pop the trunk.
The only fix I've managed to find for this is holding down the button for about 20 seconds until the car just turns on by itself; which is problematic because the key doesn't even need to be in the slot for it to turn on.
Is this a problem anyone else is having or has had? and is there an easier fix than replacing the whole slot?
Old Apr 4, 2013 | 09:00 PM
boOst spIKe's Avatar
boOst spIKe
Replace Starter/Stop Switch. Very common failure for 2007 MCS.
Old Apr 5, 2013 | 08:02 AM
mimaal's Avatar
mimaal
Where is the starter/stop switch? it that located behind where you would insert your key?
Old Apr 5, 2013 | 08:19 AM
Braminator's Avatar
Braminator
First welcome aboard. Here is where the keyfob goes and notice the starter button. Can you post some pics of your MINI?
Old Apr 5, 2013 | 08:36 AM
+1 sounds like it is shot.
Here is the part.
http://www.ecstuning.com/Search/61359299332/
Old Apr 5, 2013 | 10:19 PM
mimaal's Avatar
mimaal
the start button works perfectly, the other part is whats messing up i think. It wont even register that the key has been inserted at all, even though the battery in the keyfob is new and fully charged
Old Apr 5, 2013 | 10:20 PM
mimaal's Avatar
mimaal
and what pictures would you like?
Old Apr 6, 2013 | 10:12 AM
Chimera's Avatar
Chimera
What are you expecting the key fob to do? If the start/stop button works then the fob is being recognized by the car. Do you have comfort access (little black button on the door exterior door handle)? If so the fob doesn't have to be in the holder at all and the holder doesn't do anything. The fob just has to be in the car, step on the clutch (or brake if its an auto box) and hold the start button.
Old Apr 7, 2013 | 02:02 PM
mimaal's Avatar
mimaal
When the key is inserted its supposed to light the dash up and turn on the radio. Mine does not
Old Apr 7, 2013 | 02:17 PM
Kirby11's Avatar
Kirby11
When I put my fob in the slot mine doesn't do anything until I hit the start button. I think inserting the fob is akin to putting a standard key in a slot but not turning the key.
Your first post has me confused. When you shut the car off are you hitting the 'start' (off) button first or pulling the fob out while the engine is running?
boOst spIKe
You can either take my (and other members that have chimed in) advice, or you can continue to try and convince yourself that your problem is bigger then it really is, honestly Its up to you.
Your description is spot on for a failure to the Start/Stop switch. But hey, what do I know...
If your concerned @ difficulty of replacement, I can assure you it will be one of the easiest installs you've every performed and if you want I can PM you instructions on how to remove and replace it.
Old Apr 8, 2013 | 08:46 AM
mimaal's Avatar
mimaal
In the owners manual it says it is supposed to, and mine used to but now it doesn't.
Old Apr 8, 2013 | 08:48 AM
mimaal's Avatar
mimaal
& i hit the button then take the key out then hit the button again.
What im worried about is the fact that my car can be turned on by anyone just by holding the start button for 30 seconds with or without key
Old Apr 8, 2013 | 08:52 AM
Chimera's Avatar
Chimera
I checked this morning on my 09 with comfort access. Putting the fob in the slot does indeed turn on the radio, but it's not something I've ever done (or will likely ever need to do) because the keys never leave my pocket.
mimaal's Avatar
mimaal
Terribly sorry for not believing the first random post in this thread and asking more questions. My mistake.
Old Apr 8, 2013 | 08:55 AM
mimaal's Avatar
mimaal
Yeah everything I've looked at says its supposed to, wish i had that comfort access, my key is no better than a regular key
woodstudio
Mar 15, 2020 08:28 AM
coachvminis
Aug 17, 2015 01:42 PM
speedbird_1
Aug 15, 2015 04:44 PM
clintmeister
Aug 12, 2015 11:11 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
