Suspension Anyone using Eibach FRONT sway bar?
Old Apr 3, 2013 | 01:41 AM
pw4's Avatar
pw4
My plan for my S was soft standard suspension but strong roll stiffness - trying to keep handling sharp while the suspension is more absorbent on the rougher Australian rural roads. The soft suspension is definitely the right choice but the a stiffer front bar was hard to find and expensive to fit. But I could really do with sharpening the handling so I'm thinking about it again. I see Eibach make a front bar - anyone had any experience of it, and how easy/hard it is to fit?
I already have an Alta 23mm rear bar which I can still wind up an extra notch to keep the handling neutral, and I'm running about 1 degree negative camber just with the strut mount adjustment.
Thanks for any help!
Bennyboy
Aug 18, 2015 07:28 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
