R50/53 Rear hatch water leak
Old Mar 24, 2013 | 08:25 AM
LJcoop02's Avatar
LJcoop02
So I bought my mini about 6 months ago and I have had this water leak since I bought it. I originally thought it was my third brake light so I took that out and resealed it. Still leaks. I had my friend spray the entire hatch the other day while I sat in and watched where it was coming from. I have narrowed it down to the L-shaped clips that hold the upper window trim on. Has anyone had this problem? I don't really understand how they even seal in the first place as its just a clip going into hatch above the window seal unless they are supposed to have some kind of seal on them as well. Any help/suggestions is greatly appreciated.
Old Mar 24, 2013 | 09:46 AM
ZippyNH's Avatar
ZippyNH
Have you looked around the regular brake lights?
I suspect that water was only getting in the clips cause of the directed water stream....just letting the hose SIT on the roof, and letting the water drip might be more useful....
The regular brake lights should have a very soft foam gasket around the edge, about an inch or so from the part that sticks out...the lens.
The look at the sunroof drain....or the actual handle for the boot.
Old Mar 24, 2013 | 09:56 AM
LJcoop02's Avatar
LJcoop02
I do know that the tail lights leak a little bit which I'm going to fix as well. But when it was raining pretty hard the other night I went out and laid in the back and watched where it was coming from. There were two drops coming from those clips and it was steadily dripping right onto the floor filling up my battery bucket.
Old Mar 24, 2013 | 10:03 AM
ZippyNH's Avatar
ZippyNH
One more thought....the pic shows a missing part...i think...you have the trim off to show vents right?
Old Mar 24, 2013 | 10:13 AM
LJcoop02's Avatar
LJcoop02
Ya I just popped it off to show the clips
Old Apr 15, 2013 | 06:36 PM
rodney_kranz's Avatar
rodney_kranz
I happen to have the same problem on my rear hatch but at the bottom. The water comes it at the clips in several places. I bought new clips and trim and removed the old ones. However, removal of the old clips required breaking them because there was no way to reach the proper release tab from the other side. The big problem is that it now looks like I must REMOVE THE REAR GLASS in order to insert the new clips!!!! What did you do? Did you replace the clips? If so, how did you get them inserted? I fear I am stuck visiting a glass place to help me finish this job.
Old Apr 17, 2013 | 05:35 PM
LJcoop02's Avatar
LJcoop02
That's what I figured I would have to do. I haven't dealt with it as of right now but I need to asap. Do the new clips come with some kind of rubber seal on them? I just don't understand how these are supposed to work.
Old Apr 17, 2013 | 06:34 PM
rodney_kranz
Yes, the new clips have a rubber ring at the bottom of it where it contacts the car. I would not call it a "seal" though. I think the rubber trim is supposed to hold back most of the water.
I went to an auto glass place today and they agreed with me about it. Problem is they won't do a "labor job" which they consider this is. Anyways, now I really regret breaking the clips. So I recommend leaving your clips alone and buy a new trim piece only. You can always resort to replacing the clips later if the trim alone is inadequate.
Old Apr 18, 2013 | 11:23 AM
LJcoop02's Avatar
LJcoop02
Is your trim not sitting flush against the hatch? Mine sits flush but it can be easily removed, possibly easier than it should be I guess ill try replacing that trim before I take rear glass out and such.
Old Apr 25, 2013 | 06:50 AM
rodney_kranz
I have now managed to repair my car. To answer your question, now that the trim is installed, it sits somewhat flush, but now I think the trim is not intended to seal. The seal is mostly accomplished with the clips. I pressed the new clips in with a painter's tool, carefully without scratching the car. It took a decent amount of force on some clips, and others went in easily. One clip broke on the way in and I had to buy another one. Once the clips were in place, the rubber seal underneath actually sealed very well. Before installing the trim, I hosed the car down and the seals held. (the black splotches in the picture is paint primer to protect from rust where I scratched the paint when removing the old clips)
Attached Thumbnails Rear hatch water leak-a-new-clip.jpg   Rear hatch water leak-a-clip-before-pressing-in.jpg   Rear hatch water leak-using-a-painters-tool-to-press-in.jpg
Old Apr 26, 2013 | 03:26 PM
LJcoop02's Avatar
LJcoop02
I have now managed to repair my car. To answer your question, now that the trim is installed, it sits somewhat flush, but now I think the trim is not intended to seal. The seal is mostly Iaccomplished with the clips. I pressed the new clips in with a painter's tool, carefully without scratching the car. It took a decent amount of force on some clips, and others went in easily. One clip broke on the way in and I had to buy another one. Once the clips were in place, the rubber seal underneath actually sealed very well. Before installing the trim, I hosed the car down and the seals held. (the black splotches in the picture is paint primer to protect from rust where I scratched the paint when removing the old clips)
That looks like your working on the lower part of the rear glass correct? Mine is definitely leaking up top, either way this helps because if the lower clips have rubber seals on them the upper ones must have them as well.
Old Apr 29, 2013 | 06:41 PM
rodney_kranz
Yes, this is the lower part of the rear glass, and on an '05. Just to be clear to others: I did not have to break or remove the glass to get this done.
Old May 25, 2015 | 10:32 PM
UW Mitch's Avatar
UW Mitch
Rodney - thanks for posting your pictures. I know this is a super old thread but helpful as I've had a hatch leak and found a couple of the places, but didn't get it all. So I removed all the interior trim and had my wife run a hose. Sure enough those little clips had water pouring through them. I'm going to try a simpler first line of defense and bury them in silicone. If you have to break them to get them out anyway, I might as well try sealing them first.
Cheers!
Mitch
Old May 26, 2015 | 01:51 PM
Clips at the bottom with new trim. Bottom rear window: 51137051531
http://www.ecstuning.com/Search/SiteSearch/51137051531/
Old May 27, 2015 | 12:06 AM
Kahnfucious's Avatar
Kahnfucious
Clips at the bottom with new trim. Bottom rear window: 51137051531 http://www.ecstuning.com/Search/SiteSearch/51137051531/
ECS do you have the top moulding and clips available as well? Link to part?
Old May 27, 2015 | 08:56 AM
http://www.ecstuning.com/Search/SiteSearch/51317054068/
And
http://www.ecstuning.com/Search/SiteSearch/51317051502/
Old Jun 14, 2015 | 04:34 AM
Kahnfucious
@ ECS or anyone else - got these clips the other day from you ECS... any clues on how to remove the old clips - they seem to be pretty much stuck there. is there a special tool?
Old Jun 15, 2015 | 02:02 PM
pilotart's Avatar
pilotart
Well I sure hope your seal replacement fixes it.
If you have a Sunroof; they have four drains (each corner at sides) you must keep cleared.
In 1969, I foolishly traded in my (bought new) '67 Firebird Convertible because no one knew about the simple litttle drains for the 'top-to-body' trough, car was perfect in every other way. Ended up with the mother of all Lemons Grand Prix.
Cured me of all new cars for nearly 40 years, my MINI's a keeper for sure.
Art
Old Jun 15, 2015 | 02:11 PM
Kahnfcouis , don't see any diagrams or special tool the clip does set under the edge of the glass. Can its wiggle out after you take that clip part off. Its so tight it looks like you have to do with the glass out. Do you have better pics of the old clip installed ?
Cereall
Sep 5, 2019 06:05 PM
Toolman
Jan 20, 2016 06:50 AM
KrisMiss
Jan 3, 2016 02:02 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
