R50/53 Rear fog help needed
Old Mar 23, 2013 | 02:32 PM
MCS 5's Avatar
MCS 5
R53, production date 06/06:
I installed the light, had the wiring tucked away, took it to the dealer to program and my car lacks the wire from the black plug behind the panel to the BCM. Uhhh, so now what??
The tech said you can pull the wire/pin for the driving light and move it to the blank slot for the fog lights in the black plug behind the switch panel. I don't get it, doesn't that wire still just go to the BCM? Basically I see it as just moving the signal source to the next switch. He also suggested running a wire from the switch panel to the BCM. I'm perfectly comfortable with that, but where do I run the wire to, and which pin do I plug into?
Has anyone else dealt with this?
*i do not want to use an external switch, or hook it up to the brakes - I want it to function 100% OEM.
Old Mar 23, 2013 | 07:55 PM
rkw's Avatar
rkw
Can you explain that a bit more? You have the wiring harness and plug behind the bumper, but apparently it doesn't go to the BCM? How did the dealer determine that? Did they take out your footwell panel and check the connector at the BCM? It's an output-only line and I can't think of any way to come to that conclusion without checking the physical wiring.
That makes no sense at all.
BTW, no need to cross post the same question multiple times.
Old Mar 23, 2013 | 08:00 PM
MCS 5's Avatar
MCS 5
Sorry, I was trying to spread it out for answers.
To clarify, there is no wire in the pin that sends signal to the BCM.
Well, I know why I get paid handsomely to so car electronics. Had the fog working in 10 minutes (after programming).
Since I didn't have a wire from the switch to my BCM, I put a pin in the blank spot (to the left of the black w yellow stripe) and I jumped that pin to the black/ yellow. Ignition on, lights on, hit the switch and viola, fog turned on.
Old Mar 23, 2013 | 09:09 PM
rkw's Avatar
rkw
Okay, I misunderstood. Glad you were able to figure it out.
Dec 23, 2015 10:36 AM
wkp1219
Nov 13, 2015 07:52 AM
Aug 7, 2015 05:56 AM
