R50/53 Lame auto window question
Old Apr 16, 2004 | 02:25 PM
jdemaria's Avatar
jdemaria
I was reading through my new owners manual trying to find the section were it shows you how long and what button on the key do you use to do the all window open thing.
The salesman at the dealer showed me how to do it but I don't remember.
Could someone tell me how.
Thanks so much.
JD
Old Apr 16, 2004 | 02:39 PM
wdfoto's Avatar
wdfoto
You have to put the key in the door to close all the windows and sunroof at the same time.
Old Apr 16, 2004 | 02:40 PM
C4's Avatar
C4
>>Thanks so much.
>>JD
use the power lock toggle switch. To open all windows and sunroof (if so equipped), just press the power lock switch up (Unlock) and leave it there... However, to open both windows all the way down, you have to leave the toggle switch up, releasing it will cause the windows to stop (Auto down feature is only supported by each individual power window toggle switch).
Hope this helps!
Old Apr 16, 2004 | 02:42 PM
C4's Avatar
C4
On the driver's side door exterior handle key fob:
Turning the key clockwise, will cause windows/sunroof to close.
Turning the key counterclockwise, will cause windows/sunroof to open.
Old Apr 16, 2004 | 02:46 PM
sbgobig's Avatar
sbgobig
Press and hold the WINGs on your key to open both windows and sunroof. You may need to hold it for awhile.
I have also heard that if you turn your back to the car, bend over and aim the key at the antenna from between your legs it works as well.
Old Apr 16, 2004 | 03:04 PM
jdemaria's Avatar
jdemaria
Thanks for all the tips and I like the between the legs idea. I think I will put my legs out the window for more reception.
surfblue
Oct 24, 2018 01:20 AM
Dec 23, 2015 10:36 AM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
Bennyboy
Aug 18, 2015 07:28 AM
