Suspension time for ball joints on 60k mile 2006 r53?
Old Mar 15, 2013 | 06:31 PM
gary87xj6's Avatar
gary87xj6
i am lowering the front subframe for powerflex: sway bar bushings, steering rack bushing and control arm bushing and wondering if i should do the ball joints while they are accessible. any thoughts?
not having any issues but want to get as much done while the subframe is lowered.
thanks for your input
Old Mar 15, 2013 | 07:13 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Why wait? I suggest that, while you're there, it's the prudent thing to do. In all probability, you'll find that, once you get there, they're pretty well-worn. If you don't want to lower the subframe, thanks to a fellow NAM member who suggested the easy way to get to the inner ones is to pull the hubs out, thereby allowing the half-shafts to be raised for clearance.
Old Mar 15, 2013 | 07:14 PM
Braminator's Avatar
Braminator
It cant hurt to change them considering they have 60k. Maybe this will help http://www.pelicanparts.com/techarti...eplacement.htm
Old Mar 15, 2013 | 11:04 PM
gary87xj6's Avatar
gary87xj6
thanks for the input, any other items I should consider while I have the subframe off?
Old Mar 16, 2013 | 08:06 PM
minsanity's Avatar
minsanity
Clean your PS fan, swap out the PS hose clamps, check all boots.
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
rphox2003
Aug 5, 2015 11:34 AM
