Suspension KSport?
Old Mar 13, 2013 | 06:36 PM
ChickenBreast53's Avatar
ChickenBreast53
KSport?
Quick question, has anyone used KSport RR (Road Race) coilovers on their R53? I'm trying to decide on coilovers, and KSport's seem to be pretty nice quality, found em for less than 1k with pillowball uppers, camber plates, all that jazz. RR's are 14k f/r, pretty stiff, still looking at the AR (Asphalt Rally) which are 9k f/r but i don't think they'll go as low. any input would be appreciated!
Old Mar 18, 2013 | 06:40 AM
Pflashinaz's Avatar
Pflashinaz
Kontrol Pro
Nothing on the RR series, but plan on installing a set of Kontrol Pro's this week, time permitting.
Old Mar 18, 2013 | 06:53 AM
andyroo's Avatar
andyroo
14k? lol.
What kind of tires and what size do you run?
Old Mar 18, 2013 | 07:06 AM
Helix13mini's Avatar
Helix13mini
The seals will be the weak point. I've seen those shocks leak within a year. Also, a pillow ball bearing is excellent for race cars, because it has very little deflection, but for street cars it's not so good. Corrosion and road grime can get into the bearing surface and degrade it. It'll be only a matter of months before it starts to clatter. A bearing with a flexible media like rubber or polyurethane will last much longer and is recommended for street cars.
Old Mar 22, 2013 | 05:42 PM
BluPrynt78's Avatar
BluPrynt78
What year Mini will you be installing these on??? And can we get pics of the before and after as well as the install?
Please and thank you
Old Mar 25, 2013 | 06:53 AM
Pflashinaz's Avatar
Pflashinaz
These will be going on an 02' MCS. Photos will be posted when job is completed.
Old Apr 2, 2013 | 07:08 AM
Pflashinaz's Avatar
Pflashinaz
Ksports are on and they provide a very nice ride. Height adjustment couldn't be easier, and you don't have to adjust the springs to adjust height.
I will be putting on some miles before I start with the adjustments, but for now this setup is much better than the one I had before. Don't believe what you read about the pillow ball being bad for street!
Thanks to Jerry @ Eurotechs
Dman88
Feb 22, 2015 10:12 AM
yukinoinu
Dec 31, 2014 12:34 AM
Sales@BSH
Suspension Products
Mar 18, 2014 01:56 PM
Sales@BSH
Suspension
May 2, 2010 06:10 PM
