Pricedrop on MINI FlexPod Gauge Mounting Kit
Old Mar 12, 2013 | 09:50 AM
Mini Mania's Avatar
MINI FlexPod Gauge Mounting Kit |
Choose Your MINI Below
ON SALE NOW ONLY $119.00 (Regularly $159.95)
The FlexPod Solution
The FlexPod is a simple, harmless and seamless way to integrate a pair of gauges into the instrument cluster behind your steering wheel. Each of these FlexPod kits comes with everything you need for mounting, you just have to supply the gauges. Once installed, your gauges will have a factory installed look, and they’ll be in the perfect spot above the steering column for reading. Each FlexPod Gauge Mount comes with a purpose-built Flexpod Bracket, and a pair of custom 52mm (2-1/6 inch) gauge cups. The machined billet aluminum bracket attaches securely in 2 minutes, requiring no drilling, gluing or other modification. That means it is also completely reversible.
All FlexPod solutions install in 15 minutes or less and can be reversed, leaving no trace of your vehicle having had a modification. Do not drill holes in your car and please, don't glue anything to the dashboard.
andrewjg1994
Jan 29, 2021 07:45 PM
Wohnson89
Jun 10, 2020 04:53 AM
wheresaldo
Oct 23, 2015 10:17 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
