R60 About the Countryman Cooper S engine/exhaust sound
Old Mar 8, 2013 | 02:35 AM
Laule75's Avatar
Laule75
Hello,
I'm quite lucky to own a Clubman Cooper S and a Countryman Cooper S.
These two cars are great, however, I'm quite surprised and disappointed about the engine and exhaust sound from the Countryman; it looks like the sound of the countryman is not as "rasping" and lovely as the Clubman.
What do you think about the Countryman Cooper S sound ?
cheers
lau
Old Mar 8, 2013 | 05:15 AM
Pete1burn's Avatar
Pete1burn
Same. My Countryman S is in the shop and they gave me a Cooper S for a loaner. The exhaust sound and pops from the Cooper are awesome. Much more pronounced than the dull thump of the Countryman's exhaust when decelerating.
Old Mar 8, 2013 | 07:58 AM
thirdraildesignlab's Avatar
thirdraildesignlab
I honestly miss the burble of my old MCS. With the second gen MINIs, assuming you even have sport mode on, it's more restrained to my ear...
Old Mar 8, 2013 | 10:04 AM
sbdubya's Avatar
sbdubya
You can always get an aftermarket exhaust system installed. Go to your local muffler shop and see what they can do for you. I got a Magnaflow muffler installed for about $250. Now the ceramic coated flat black tips were another $90.
Check out 1bigpea for a clean install and a sound byte.
Old Mar 8, 2013 | 05:38 PM
Rktcyntst's Avatar
Rktcyntst
R60S is definitely more subdued. My wife has a R57S and that thing sounds so much cooler and pronounced like someone stated when it's fired up and running. I think I'm going to have to look for an updated exhaust to get it to purr more...
Old Mar 8, 2013 | 07:07 PM
DR61's Avatar
DR61
I like the R60 S sound. I can ID the car a block away when my wife is driving it home. I think it is better than the R53 I used to own.
Old Mar 9, 2013 | 12:11 AM
bmwr606's Avatar
bmwr606
i installed a milltek downpipe-back exhaust
it has no second cat and no resonator, only the back muffler
at part throttle/steady speed and under 3,500 rpm it is almost as quiet as stock, but over 3,500 rpm steady speed or full throttle it sounds like a proper exhaust
the off-throttle pop/burble is much more pronounced
it was an easy install, about 2 hours from ground, jacking, remove stock, install milltek and back on the ground ... i had a friend to help
low end torque is much better
scott
Getrieben
Sep 12, 2024 07:03 AM
Aug 12, 2015 01:24 PM
MiniJess
Aug 10, 2015 09:51 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
