FS:: 2007 MINI Cooper S - JCW Swap, Modded.
Old Mar 7, 2013 | 03:43 PM
Jaremy Cheetwood's Avatar
Jaremy Cheetwood
Year: 2007
Model: Cooper
Price: $13500
Mileage: 105
Color: Dark Silver
Location (Region): SoCAl
I am selling my MINI cause I am ready to dump all my money into my E30. RWD has taken over me.
So for sale we have my 2007 R56 MCS:
Mileage: 105k (Yes its high but its a drivers car)
Packages: Sport, Cold Weather, Premium, Sunroof
Color: Dark Silver
Trans: JCW 6 Speed Swap ($3900)
Diff: Quaife LSD ($1100)
Engine: Compression test came back solid
Tune: RMW Dyno Tune ($610) - 225WHP/250WTQ
Suspension: JIC-Cross Coilovers ($2400)
Intake: Stock Airbox + K&N Drop in, Alta Turbo Inlet Pipe
Intercooler: Alta FMIC ($700)
Downpipe: Catless Riss Racing DP ($200)
Catback: Magnaflow CB ($250)
Turbo: Stock K03 (Will come with an uninstalled hybrid K04) ($650)
Wheels: ESM-001 17x8 +35 ($900)
Tires: 90% (4) Kumho Ecsta AST ($400)
Windows: 20% Front, 5% Rear, Windshield tint strip
Antenna: Alta Stubby
Clutch: Spec Stage 1 ($600)
Brakes: Stoptech D/S Rotors, Stoptech Street Performance pads, SS Brake Lines (4)
Shift ****: JCW CF ****
Piping: Alta Hot side, NM Engineering Post FMIC tube
DV: Alta Stiffer Spring
Grille: JCW Grille
Scuttles: Areo Gen2 Scuttles
Recent Maintenance:
New OEM Transmission mount
New OEM Wiring Harness
New OEM Flywheel
New OEM Cam Pos Sensor
New OEM Crank Pos Sensor
New OEM Rear Pads/Rotors (6k miles)
New OEM Driver side Hub/Bearing
New OEM Tie rods (inner/outer)
New OEM 02 sensors x 2
New OEM DV
Known R56 Issues that have been serviced:
Water Pump replaced (60k Miles) OEM Unit used
HPFP Replaced (65K Miles) Dealer done
Thermostat Housing replacement (70k Miles) OEM Unit Used
Timing Chain Tensioner Replaced (Every 20k Miles from 50k - 105K)
Car is higher mileage but has all the service and maintenance to back it. Transmission was just swapped for a new OEM JCW trans after my S 6 speed failed on me. At that time I had the Cam and Crank sensors done along with a new flywheel, spec clutch and quaife LSD. Looking to start putting my money into my e30 now.
Below are some pics of the car, feel free to email or pm me for more info.
Email: jaycheetwood at gmail.com
Asking $13,500.
Attached Thumbnails 2007 MINI Cooper S - JCW Swap, Modded.-r564.jpg   2007 MINI Cooper S - JCW Swap, Modded.-003lcu.jpg   2007 MINI Cooper S - JCW Swap, Modded.-img_1502.jpg
Old Mar 7, 2013 | 03:52 PM
Minian's Avatar
Minian
Just spent 9K on goodies for my R53. IF I knew This car was for sale it would be sold!!!
I've seen many of those pics several times. I wouldn't care about the milage I can see the car was cared for. Phuc'n Suueeet!!
Old Mar 7, 2013 | 04:07 PM
Jaremy Cheetwood
Thanks for the kind words!
Definitely higher mileage but very up on my maintenance and in some areas have probably over maintained the car. I take pride in what I own so I want what i own to be at 100% as much as I can.
Old Mar 7, 2013 | 04:10 PM
Sketch's Avatar
Sketch
Much better to have a higher mileage car with very thorough service (like this) than a low mileage car with questionable history. GL with the sale, I love those wheels.
Old Apr 5, 2013 | 10:25 AM
RoyalCooper's Avatar
RoyalCooper
Awesome Set Up !!!
That is one GREAT car...105k or not
Although personally I like it better with these wheels:
Originally Posted by Jaremy Cheetwood
Old Apr 23, 2013 | 08:49 PM
Racerx06's Avatar
Racerx06
Email sent
SosoMINI
Nov 22, 2015 03:17 PM
phrza81
Oct 10, 2015 11:37 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
jrezzo
Aug 9, 2015 10:32 PM
