R50/53 21mm Strut tool?
Old Mar 3, 2013 | 06:41 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
21mm Strut tool?
I keep hearing about this special 21mm strut tool, where can I get it? How do you use it?
Old Mar 3, 2013 | 07:22 PM
Braminator's Avatar
Braminator
Here is just one place to get it. http://www.eurosportdesign.com/p-438...al-socket.aspx
I beleive many have changed the shocks without it though. Read these-
http://www.pelicanparts.com/techarti...eplacement.htm
Old Mar 3, 2013 | 07:35 PM
GreatPumpkin's Avatar
GreatPumpkin
Another option would be to make the tool yourself for about 1/3 the price. Purchase a 21mm deep socket and cut a "window" with a Dremel.
As to how to use it the socket holds the nut. The "window" allows you to insert an allen wrench and hold the shock shaft while you tighten the nut.
Old Mar 4, 2013 | 11:50 PM
drifter.locus's Avatar
drifter.locus
Using a 21mm sparkplug socket with an allen tool stuck through the end worked much better for me.
ericbryant24
55
Sep 30, 2024 02:10 PM
elverado
Jan 18, 2022 02:51 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
02proxdude
Sep 22, 2015 06:44 PM
Suspension Products
Sep 3, 2015 09:41 AM
