Suspension stock r52 shocks with jcw gp springs?
Old Mar 2, 2013 | 01:18 AM
fasfury's Avatar
fasfury
1 week before i bought used jcw gp springs for my cabrio r52 and put them on it. But i realised that my overall traction become worse then stock. Anyone have an idea about this issue? what i have to do to improve my traction? I searched the forum and came up some results that koni fsd is the cheaper and a good solution to handling issues.another question is koni fsd+ stock springs or koni fsd + gp springs which brings more traction to me?btw i dont care about lowering and the toughness. I just want to improve my cabrios traction. Thanks
Old Mar 2, 2013 | 06:00 AM
davisflyer's Avatar
davisflyer
According to Koni, FSD with stock springs only, Koni Sports with JCW springs.
Old Mar 2, 2013 | 06:13 AM
fasfury's Avatar
fasfury
By saying koni sport did you mean the koni yellows or other stuff? And what i have to do more like rear control arms or other things? i have front tower bar and thats all for suspension mods.
Old Mar 2, 2013 | 06:19 AM
daflake's Avatar
daflake
What he is saying, is that FSD struts cannot be lowered as it will damage them. If you want to lower the car, the yellows are the better option. I have the FSD struts and love them but it did raise the car a little. It all boils down to preferences.
Old Mar 2, 2013 | 06:22 AM
fasfury's Avatar
fasfury
My main aim is the best handling performance that i can achive by this car so if this can be achived by lowering it or hardening the car i can do whatever it costs.
Old Mar 2, 2013 | 06:49 AM
daflake's Avatar
daflake
If ride is not a concern, then look at coil overs. The FSD and yellows are more of a compromise between the two.
Old Mar 2, 2013 | 06:55 AM
fasfury's Avatar
fasfury
But i am looking for a cheaper option coilovers are very valuable and also expensive here. So just shock is my first option. So considering that i have both stock and jcw gp springs what is the best one according to price and handling criteria? İ dont mind how my car is lowered or how hard and harsh it is.
Old Mar 2, 2013 | 07:29 AM
Braminator's Avatar
Braminator
I beleive and you can confirm, your GP springs can be used with the FSD as they are within the limits. Call Koni and ask them on Monday.
Old Mar 2, 2013 | 07:34 AM
fasfury's Avatar
fasfury
i am not insist on using gp springs. İ just want to know which one is better on fsd's. Or someone can offer another combination with these springs which has a better handling.
Old Mar 2, 2013 | 07:52 AM
Braminator's Avatar
Braminator
Koni Yellows if you want the best handling. The FSD's will give you comfort and the yellow's will give you handling.
Old Mar 2, 2013 | 10:16 AM
daflake's Avatar
daflake
and just to add to this, FSDs do handle much better than stock.
Old Mar 2, 2013 | 11:24 AM
fasfury's Avatar
fasfury
ok thanks a lot i will definitely buy koni yellows, and anybody knows a local store which sells koni yellows near manhattan or just in new york?
Old Mar 14, 2013 | 04:18 AM
fasfury's Avatar
fasfury
I want to ask another question. My 2 options are kw variant 1 or koni yellows. Kw is 1000€ and koni is 600€ what do you suggest me? Are this two differs in handling costs 400€?
Old Mar 14, 2013 | 09:03 AM
ZippyNH's Avatar
ZippyNH
I am confused.....euro's....newyork...
Old Mar 14, 2013 | 09:25 AM
fasfury's Avatar
fasfury
no new york topic is old, now i am just wondering the price comparison between koni and kw
Old Mar 14, 2013 | 09:38 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Buy the KONI Yellows/Sports and use the GP Springs. Just springs and struts are only a part of the total equation. If you really want the car to handle well, then you'll need to get some good front camber plates, rear lower adjustable control arms and a thicker rear sway bar. Then, after a good alignment, the car will handle well if you have adequate tires.
Old Mar 14, 2013 | 10:29 AM
ZippyNH's Avatar
ZippyNH
Since $$ apears to be a concern....
you own the springs...
so you could buy tye koni yellow (regular or sport) and install them....then if you want more handling, add camber plates, and maybe a rearswaybar...
Comes down to what you want, and the quality of the roads you have...
the kw coilovers are nice, as are ireland engineering, but they are overkill for a non track car, and if roads are bad, may fail prematurely.
Comes down to do you want it to handle better better than stock, or handle like a race car...it is a slippery slope...you could spend a boatload to get a small gain compared to just the basics....sounds like that what you wanted, the biggest gain for the least $$ with the gp springs.
Koni yellow sports are imo what you want, to go with you springs, then a rearswaybar, maybe camber plates...makes a good street combo...and even a entrylevel track setup.
As said above, don't forget the basics...a good alignment when done, and the single most important thing, some driver education!!
Old Mar 14, 2013 | 10:58 AM
fasfury's Avatar
fasfury
thanks everyone all my questions even in my head were answered. i already have front strut bar, alutec. when i will buy koni's my later purchases are: rear sway bar 19mm, rear end link and camber plates. my tires are bridgestone potenza s001 and they are in great condition. The last thing is I am a radio control car racer maybe thats why I am consered with this handling issue )
Old Mar 14, 2013 | 11:01 AM
andyroo's Avatar
andyroo
Cut your bumpstops too. Highly highly recommended.
Koni yellows are good.
19mm rear swaybar, camber plates, rear control arms, and a good alignment = great set-up.
Old Mar 14, 2013 | 11:02 AM
fasfury's Avatar
fasfury
what is bumpstop?
Old Mar 14, 2013 | 11:03 AM
andyroo's Avatar
andyroo
The rubber bumper around the strut shaft. It is very firm and the Mini rests on them, making the suspension too stiff and causing a loss of grip. Cut a half inch off the firmer end, it makes a large difference.
Old Mar 14, 2013 | 11:05 AM
fasfury's Avatar
fasfury
if I dont buy koni's, i will definitely try this, thanks.
Old Mar 14, 2013 | 11:08 AM
andyroo's Avatar
andyroo
You should do it with the Konis as well.
Old Mar 14, 2013 | 11:14 AM
fasfury's Avatar
fasfury
:D ok. do I understand it right, it is like a stopper for strut for an ending position right? and cutting it a little makes the car roll more and relaxes the strut and my overall traction improves.
Old Mar 14, 2013 | 11:21 AM
andyroo's Avatar
andyroo
right. It's the "bumper" in the following 2 images:
