R50/53 HELP!! i lost 6th Gear
Old Feb 21, 2013 | 06:46 PM
GreekDrifter91's Avatar
GreekDrifter91
just today i went to go into 6th and it would not go in i let out the clutch and it just loosely grinds. like its jut kicking the gear it wont catch. all day it was fine. don know whats up... 5th gear will be sketchy some times; sometimes i have to try twice to get it to catch. but it goes in with no fuss. other than that the 5th 6th gear plane feels weird going into like pushing the lever right has been limited or something.
also lately the gear shifts have been weird like its really clicky no noise or and extra force needed just going in and out of each gear it like it has a biger notch it has to jump over or something.
anyway i am really hoping its just the cables and that they can be adjusted. i really really hope this is true, because i do not want to drop the tranny.
any ideas?
Old Feb 22, 2013 | 07:49 AM
minibx's Avatar
minibx
I hope that someone can offer some input and that is nothing major, best of luck
Old Feb 22, 2013 | 09:43 AM
GreekDrifter91
^ yea me too....
bump for any help!
Old Feb 22, 2013 | 09:51 AM
miles_miles7's Avatar
miles_miles7
Unless someone chime in with the exact same issues like yours I would just take it to a transmission shop to get to the root. I hope its nothing like major issues.
Old Feb 22, 2013 | 10:18 AM
GreekDrifter91
i was reading on anothor forum that there is a mod that can be done to the levers? any idea what that is. they gave no other info. and it was a 3 year old thread.
also sense im down there whats a good tranny oil to use. got 135k and im positive the oil has never been changed.
gonna start with the cables first book says loose or cables on there way out will cause this. which was my original idea.
Old Feb 22, 2013 | 10:24 AM
ZippyNH's Avatar
ZippyNH
Check the cables first....
If not the cables, then i'm thinking it MIGHT be a throwout bearing from your description....yhe mini uses a plastic one that can come appart....but tough to tell from the description, but the 6 speed is prett tough unless really abused, so hopefull it is ok.
might be worth looking at the master/slave , MIGHT be worth looking for fluid leaking sround the dustcover.....
Old Feb 22, 2013 | 10:29 AM
GreekDrifter91
through out bearing would not make sense to me because it would cause a problem with all the gears not just 6th and sometimes 5th.
Old Feb 22, 2013 | 12:02 PM
Braminator's Avatar
Braminator
Did you check the cables like suggested? that would be the 1st place to check. Does it go into 4th? Check the shifter box under the car and under the heat shield. See if there is anything preventing the full throw.
Old Feb 22, 2013 | 12:03 PM
FrenchyR53's Avatar
FrenchyR53
I just had an issue with 2nd gear recently, it turns out that the positive cable that runs from the battery to the engine bay got loose from its anchors right below the airbox and right above the gear linkage in transmission and was preventing me from fully engaging 2nd. The linkage was hitting the pos cable and couldnt fully engage. I took the airbox out and reattached the pos. cable properly. No more problems. There is just enough space for the gear shifter linkage to move freely. Not sure if that's what causing your problem but it solved mine. Thought I would share my experience.
Old Feb 22, 2013 | 12:18 PM
GreekDrifter91
yup R & 1-4 are perfect 5th sometimes needs a second try and 6th is a no go. but the shiftier does feel very notchy. i have not been able to get to the cables yet. im going to work in a little bit then a 12hr work day tomorrow so Sunday ill have to take a look.
good to know i will check that out.
also just picked up two bottles of redline MTL going to do a oil change on sunday too hope that fixes something too.
Old Feb 24, 2013 | 08:03 PM
GreekDrifter91
so poke around a little today. cables and posts are fine. its 100% internal....
very likely its the 6th gear syncro or a retaining clip jumped out of its groove and now the gear just floats around the shaft.
also changed the oil shifting is heck of a lot nicer now.
Old Feb 24, 2013 | 08:16 PM
GreekDrifter91
oh also would like to add that i can put it in 6th from a dead stop and get it rolling and cant get it in gear when the car is in motion so its a synco most likely but why 6th it dosent make sense to me that take no abuse what so ever.
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
bmanrkg3
Sep 18, 2015 12:11 PM
Rainforest_Elf
Sep 16, 2015 10:13 AM
Rainforest_Elf
Sep 15, 2015 12:11 PM
Timmy_r53
Sep 14, 2015 01:59 PM
