R56 Timing chain Tensioner... AGAIN!!!!
Had my chain, tensioner and guide rail replaced under warranty 4 months ago. Looks like the rattle is back.
has anyone had to replace these components twice ?! if so what could be making it go bad again?
could this be a lemon?
Did you buy your Mini new? How many miles do you have? How many miles to you add during the 4 months? There could have been a defective part or the mechanic possible didn't torque everything properly.. Get it right back to them before incurring more damage and expense.
Hi, mine was done at 68,240 k. and now I'm hearing a noise again. Taking it in for a check and praying its not that again. This was 2 years ago. Last year had the coolant pump replaced due campaign and now thermostat housing is leaking coolant. Yikes. I bought this car in June thinking most issues were resolved...apparently not.
Check your oil level the car will make a similar sound if you are low on oil, as in a few quarts low
If left unchecked and it is tensioner / timing chain related you could trash the motor. If the chain is loose it starts slapping other parts or could jump teeth on the sprocket. The work you had completed 4 months ago should be under warranty.
Wow! Thank you blakeslee, you were right! I came home and added 2.5 quarts of oil and sound is gone. I am upset with myself though because I have been checking the oil and I have never had more trouble reading a dipstick in my life than with this car. I feel like an idiot but even my son said it was fine a couple weeks ago. I hope I didn't do any damage driving with that noise for the past two weeks.
Now wondering why it's burning so much oil. This is the second time since I purchased it in June that it took 2 quarts. Thanks again for your helpful information.
Patsy
Patsy
Well I talked to Mike at our local dealership here and he explained it sounded about right that 6.5 quarts oil have been added to my car in the last year. He said it's normal for a quart/month when I expressed concern over why so much oil? That just seems like a lot to me do paired to my last car.
+1 my 2010 doesn't burn oil either. I do change the oil every 5~6K miles. I do not grandma it though lol.
09R56
Nov 16, 2022 10:49 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
