R60 Change to Intake Manifold?
Old Feb 18, 2013 | 08:56 PM
cbryantnyc's Avatar
cbryantnyc
Fellow NAMers I need some help. I recently purchased a SeaFoam fogger kit for the N18 from DOS. Unfortunately, it looks like MINI may have made a change to the intake manifold that makes the kit unusable. In the diagrams for the OEM parts you can see that the intake manifold was made up of 2 parts (parts 7 and 8). In the pics of my intake manifold you will see that it is one solid piece and no longer rubber but a thin plastic. My Countryman is an S ALL4 and was produced in 5/2012. Is there anyone out there that has the same piece that is willing to see if they can find a part number? I cant get access to the lower hose clamp and thus can't get the number myself. Also having zero luck in finding any diagrams that show this piece. Any help would be much appreciated. Thanks in advance.
Attached Thumbnails Change to Intake Manifold?-realoem.jpg   Change to Intake Manifold?-img_1135.jpg   Change to Intake Manifold?-img_1137.jpg
Old Feb 18, 2013 | 09:20 PM
Bakerbrdz's Avatar
Bakerbrdz
Weird, mines a rubber hose like the one on the website. Watch out for those venders....
Old Feb 18, 2013 | 09:24 PM
cbryantnyc's Avatar
cbryantnyc
I wanted to add that Clint over at DOS has been great in trying to help me with this. He too has not seen the version that I have. As soon as I can get a part # he is going to get a sample and get me a new setup.
Old Feb 18, 2013 | 11:10 PM
Mini'mon's Avatar
Mini'mon
MINI made a some part changes in their recent 2013 N18 engine builds. They are eliminating some of the rubber hoses and replacing them with plastic hoses much like the OEM induction hose.
So far we've seen that they've replaced at least one of the intake manifold hoses and the valve cover PCV hose with this new material. It's a smart move because these hoses should be cheaper to make. Unfortunately, they have not released the part numbers for these replacement hoses to their North American dealer network at this time. DoS wants samples of these hoses so we can measure them, but MINI is not being especially helpful.
cbryantnyc, because MINI can't hook us up, DoS will fabricate a custom hose for you. We will then use this new hose for our 2013+ N18 Sea Foam Fogger Kits.
Best,
-Clint
Old Feb 19, 2013 | 07:55 AM
countryman2b's Avatar
countryman2b
Same part on my MINI countryman , producted 5/2012.
It's crazy but i changed it by the old part because i've got 2 samco hoses for the intake manifold...
And sorry but i do not have the old hose (-> garbage ), the new, you see ...
"I cant get access to the lower hose clamp and thus can't get the number myself." = to acces it you ahve to pull off the air box to have more space to work and access to this hose clamp
Old Feb 19, 2013 | 09:53 AM
Mini'mon's Avatar
Mini'mon
cbryantnyc, I talked with our distributor today and finally found the part number for the new plastic intake hose on your 2013 Countryman S.
We'll ship out a fogger kit to fit your MINI by Thursday afternoon 2/21/13.
-Clint
Old Feb 19, 2013 | 06:42 PM
cbryantnyc's Avatar
cbryantnyc
Clint,
Thanks for standing up to the quality reputation you have on this sight and finding a resolution to my problem so quickly. I look forward to doing business with you again when you figure out the Countryman CAI solution.
bobbiemartin
Jan 20, 2016 05:28 PM
sprp85
Aug 22, 2015 06:16 AM
Indimanic
Aug 19, 2015 11:08 AM
FLYM1N1
Aug 16, 2015 01:17 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
