R56 Fog bulb replacement
Old Feb 12, 2013 | 08:14 AM
quattro4's Avatar
quattro4
I moved the tire, opened the housing, turned the bulb counterclockwise... The thing doesn't move.
Now I'm determined to get it out.
Any suggestions???
Thanks everyone!
Old Feb 12, 2013 | 09:47 AM
Velocityvic's Avatar
Velocityvic
I still have scars from the drivers side. I didn't know I was going to remove skin while removing the bulb. Keep trying...it's hard to get any leverage.
Old Feb 12, 2013 | 01:20 PM
ammodave's Avatar
ammodave
If it's well and truly stuck, it may be easier just to remove the whole headlight assy from the car (4 bolts and one electrical connector). I can remove and replace both my headlights in 10 minutes without having to bend over or skin my knuckles.
Old Feb 12, 2013 | 01:44 PM
calforhelp's Avatar
calforhelp
I ended up getting mad at mine when I was installing my LED bulbs. I just forced the bulb out by twisting the socket with all my might. It broke all the little plastic tabs on the fog bulb socket but the bulb sits tightly in there now and is easy to take out when I want it!
I'd probably still suggest doing it the right way tho.
Old Feb 12, 2013 | 02:02 PM
RJKimbell's Avatar
RJKimbell
It makes it much easier if you can jack up the side you are working on, turn the wheel in as far as it will go to gain access. I was lucky and had someone help me who has a hydraulic lift.
Old Feb 12, 2013 | 06:06 PM
quattro4's Avatar
quattro4
Victory!!!
I did skin my hand but I rather my hand than my Mini. I think most of us here feel the same way.
Thanks everyone.
Old Feb 13, 2013 | 10:25 AM
FIRESTARTER's Avatar
FIRESTARTER
Remove the connector before removing the bulb.
Aug 19, 2015 12:51 PM
I_drive_slow
Aug 18, 2015 10:47 AM
AZN Optics
Aug 16, 2015 11:52 PM
