R56 dealer overfilled oil
Old Feb 8, 2013 | 01:39 PM
dpcompt's Avatar
dpcompt
At my first service(12,000mi.), the dealer put in 5 quarts instead 4.4 quarts. I mentioned that the dipstick displayed overfill. The SA told me that they routinely overfill the R56S because they use a little oil. He told me that it would not cause any damage. Any opinions?
Old Feb 8, 2013 | 01:42 PM
wandrur's Avatar
wandrur
Moderator
Inserted the truer statement:
Originally Posted by dpcompt
The SA told me that they routinely overfill the R56S because they hire people who honestly can't read.
Old Feb 8, 2013 | 01:49 PM
///Chris's Avatar
///Chris
An extra 1/2 quart should not be enough to worry about, especially if there was a filter change involved. The turbo does consume a small bit of oil over the 12,000 mile service interval, although probably not 1/2 quart. I would worry if it was grossly overfilled though.
I also wouldn't worry much about it because I know that when I race my e36, the common accepted practice is to add an extra quart (bringing the total up to 8(!)).
Man, just thinking about five quart oil changes is making my wallet happy!
As an afterthought, if anything bad does come of it - the car is still under warranty. If you are worried about it, call the service manager.
Old Feb 8, 2013 | 02:01 PM
MNIPWR's Avatar
MNIPWR
unsubscribed
Old Feb 8, 2013 | 02:14 PM
dpcompt's Avatar
dpcompt
Thanks for your reply. Your opinion is shared with the dealer. I just got a little spooked after reading the owner's manual.
Old Feb 8, 2013 | 02:24 PM
ocluck's Avatar
ocluck
my mini runs smoother filled to the top bulge of the dipstick and not over filled. my dealer over filled with 5 qts and it ran rough. i took out a bit then my mini ran smooth again.
Old Feb 8, 2013 | 02:25 PM
///Chris's Avatar
///Chris
Here's a fantastic article I just found about oil and the Mini R56. It's worth a read.
http://www.clubscmm.com/board/index.php?topic=8979.0
Old Feb 8, 2013 | 02:33 PM
countryboyshane's Avatar
countryboyshane
Holy cow that's the most in depth oil thread I've ever seen for the MINI!!!
I have always put in 5qt in mine. Mine barely eats any oil either.
Old Feb 8, 2013 | 02:34 PM
///Chris's Avatar
///Chris
Yeah, it was pretty intense. I like that though!
Old Feb 9, 2013 | 06:21 AM
byron h's Avatar
byron h
I would pump the excess oil out. You can get a pump like JoanieB showed in the following post for less than $20. I bought mine at Advanced Auto and it came with a tube that slid down the dipstick tube. If you pump out the oil instead of loosening the drain plug, you don't ruin the crush washer. I don't believe in running the oil above the maximum level.
Morris, 2011 MC, PW/B
https://www.northamericanmotoring.co...56-post26.html
Old Feb 9, 2013 | 09:17 AM
Hujan's Avatar
Hujan
Hmm. My dealership was just running a special on DIY oil change kits: Two filters and 12 quarts for $100. When I asked why 12 quarts, I was told: "Five for each oil change, plus an extra quart to add oil as needed between changes."
So of course I put 5 quarts in on that advice. Now all I can think about is foamy engine oil.
Old Feb 9, 2013 | 12:36 PM
Porthos's Avatar
Porthos
That whole post just made me have a stroke. No but, seriously I need to get up off my *** and sign up for SCMM.
sevin
May 2, 2026 06:11 AM
woodstudio
Mar 15, 2020 08:28 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
HaveATank
Aug 24, 2015 10:26 AM
stellaherself
Aug 13, 2015 03:48 PM
