Helix at the Dragon: Specials!
Old Feb 5, 2013 | 12:21 PM
Helix13mini's Avatar
Helix13mini
Helix Minisports will be back at the Dragon this year, with some cool new installation specials for both 1st generation and 2nd generation MINIs. We are currently taking appointments for installations of all kinds from something as small as a Helix stubby antenna, to a replacement clutch (we've always sort of wanted that challenge).
This year we will be featuring a few unique specials. For the R50 and R53s (2002-2006 MINIs), we are offering Powerflex polyurithane control arm bushings installed for $350 total. If you own a 1st generation MINI, have more than 50,000 miles on it, and haven't replaced your bushings, unfortunately, you'll need to. You may have noticed that your MINI's handling is sloppier than it used to be, and that your inner tires have worn out. That's because your control arm bushings have failed. You could replace them with factory bushings, but then you'd just have to replace them in 40 to 50k miles. That's where Powerflex bushings come into play. They last the life of the car and make your handling razor sharp. Lend us a little time with your MINI and we'll make it the best Dragon experience of your life!
For the R56 and later cars (2007 and on), we're offering two unique services. First, Vehicle Coding. We are able to switch on a number of special commands within your vehicle's computer to activate conveniences that you may not have gotten with your MINI. Everything from automatically rolling up your windows with your keyfob, to controlling the torque steer under hard acceleration. How about one-touch sunroof open and close? Here's a partial list of what we can do:
· Remote closing windows-closing with fob
· Auto Door Unlock- Unlocks all doors when you remove key (regular) or when the engine shuts off
· Selective Unlocking with Remote- unlock all doors, just the drivers door.
· Power Windows after Ignition Deactivation- Enables power windows for one minute after ignition is turned off
· Efficient Dynamics- shift indicator suggestions enable when cruising
· Always Show Digital Speed- Keep Digital speed in tach
· Disable speed overestimation- Drops the speed read out 2-7 mph
· Key Gong Reminder -door open- disable
· Road Freeze Temperature Warning- disable
· Opening Doors Will Not Interrupt Window Roll Up
· Double-Blink Hazard Lights/ Euro blinker
· Fogs and High Beams On Simultaneously / or when flashing
· Disable A/C Engagement When Pressing the Auto Button
· Disable NAV System Warning
· Sunroof Auto Open/Close- From tilt full open with one touch and close as well
· Heart beat tach- Activates the alarm bar on top of the tack to “pulse on and off”
· Disable Seat Belt Chime- both driver and passenger
· Change Standard (standard) Radio Filter Settings- takeout low end filter for rear speakers. CAUTION!!!!!! MAY BLOW OUT REAR SPEAKERS
· Disable Bulb checks- Void warnings for after market lighting
· Enable one-touch windows on R56 models (driver/passenger)
· Remove Legal disclaimer from Connected or Nav
· Interior lighting cycle speed
· Rain sensor closes sunroof
· Fogs come on with lights – (disables toggle switch)
· Torque steer fix!!!- (still in testing)
We will be running a special for coding: $20 per code or as many codes as you want for $60.
Finally, if you have a R56, you've probably heard of the dreaded carbon build-up on the intake valves. It robs the cars of performance, efficiency, and smooth operation. There's only one reliable way to clean off the build-up, and that's a Walnut Shell Blasting service. We'll be offering it at the Dragon for $350--less than half of what MINI dealerships charge to do the service. We have the factory tools to get it done right, and make your car run as it did when it was new.
If anybody has questions, or would like to reserve a time slot with us, please call Helix at 267 335 4337.
In other good news, I've paid my speeding ticket from last year.
Old Feb 7, 2013 | 07:51 AM
Helix13mini
...And of course we'll be doing a host of performance modifications, such as Pulleys, swaybars and short shifter kits.
Old Feb 10, 2013 | 07:30 AM
kconner5's Avatar
kconner5
Awesome! I'll definitely have y'all code my car when I'm down there. Dragon Fever is building!
Kyle
Old Feb 12, 2013 | 08:52 AM
Helix13mini
Kyle
Thanks, we've got you down for Friday.
Old Feb 12, 2013 | 04:48 PM
gr8ful's Avatar
gr8ful
How about R57? I have picked 6 codes that need fixed. Any extra one's for the Cabrio?
I will call and make my appointment in the morning.
Old Feb 14, 2013 | 07:17 AM
Helix13mini
We're coding fools! Drop us a line and we'll see you at the Dragon!
Old Feb 14, 2013 | 08:41 AM
DAVESTER's Avatar
DAVESTER
Is there a cure for one-touch auto up for the R58 yet?
Old Feb 17, 2013 | 02:41 AM
er.'s Avatar
er.
Originally Posted by davester
is there a cure for one-touch auto up for the r58 yet?
+1
Old Feb 17, 2013 | 02:44 AM
er.'s Avatar
er.
Can you make the R58's doors lock sometime after you get out? They don't lock ever...
Old Feb 22, 2013 | 06:33 PM
Mindspin311's Avatar
Mindspin311
Definitely interested in this if I decide to attend. Love to get some coding done.
Are you guys able to determine if the walnut blasting is needed?
Old Feb 23, 2013 | 02:14 PM
Squirlz's Avatar
Squirlz
Eric, did you get my message regarding bushings on Molly's car?
Old Feb 25, 2013 | 05:47 AM
er.'s Avatar
er.
I'm getting the impression that he's not checking in here for every post I'd suggest calling the phone number he asked us to use: 267 335 4337
Old Feb 25, 2013 | 05:58 AM
DAVESTER's Avatar
DAVESTER
Did you get an answer on your question?
Old Feb 25, 2013 | 05:59 AM
er.'s Avatar
er.
I didn't call yet...planning to do that today. Will update.
Old Feb 25, 2013 | 07:28 AM
Helix13mini
I'm not sure that I did...Wazzup?
Old Mar 3, 2013 | 09:08 AM
Squirlz's Avatar
Squirlz
I wanted to reserve a spot to have bushings replaced on Molly's R53.
Old Mar 3, 2013 | 11:08 AM
DAVESTER's Avatar
DAVESTER
Eric, what about coding a R58?
Old Mar 3, 2013 | 11:20 AM
Vassago68's Avatar
Vassago68
Wish I could get there this year. It will have to be next year when I move back to the states.
Old Mar 3, 2013 | 03:44 PM
user 837978240's Avatar
user 837978240
Count me in for more coding goodness!
Old Mar 4, 2013 | 06:44 AM
Helix13mini
Why don't you give us a ding and we'll schedule you at a time that you're not at an event. 267 335 4337. -E
Old Mar 4, 2013 | 06:51 AM
Helix13mini
Davester, G33:
We can code R58s. Our schedule is filling up, so if you have a specific time you want the work done, you might consider locking it in with us before hand. Of course we'll work late to be sure everybody gets taken care of.
Old Mar 6, 2013 | 07:17 AM
Dozuki01's Avatar
Dozuki01
Can we get the specials done before coming down to the Dragon - Bring the Mini down to your shop.
Old Mar 6, 2013 | 07:19 AM
Helix13mini
Give us a call, we'll take care of you.
Old Mar 6, 2013 | 01:50 PM
Dozuki01's Avatar
Dozuki01
Just schedule an appointment with Rob and will be down Monday afternoon for Control Arm bushings, codes and check out my any bushings I may need.
Old Mar 7, 2013 | 06:22 AM
Helix13mini
Cheers! We'll see you there.
