R50/53 Up and died
Up and died
Driving home from work on interstate, car just died no sputter just stopped. Pulled over and smelled fuel. Upon opening hood found the vacume line off the fuel pressure regulator, hooked back up no start but fuel leaking, so I assume the pressure regulator is toast. Any suggestions?
Dan
Dan
Get a mate to unscrew the FPR and stand statue still when the unit releases. Push the car straight back about 8'. Pry the defective unit out of his hand and put the new one in his grip (the same way up). Roll the car forward 8'. Get you mate to screw the new one in as it should be right over the hole. Tighten into place and refit vacuum hose.
That should fix it. (Sorry: Could not resist it. What other answer could be expected???)
elverado
Jan 18, 2022 02:51 AM
patsum
26
May 29, 2021 06:29 PM
R50/53 Help please.. Odd issue.
PsychoRallye
21
Feb 17, 2019 06:08 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
R50/53 What is up with my 2005 r53?
rustof
11
Sep 25, 2015 10:35 AM
