Oil spot and smoking
Old Jan 29, 2013 | 05:52 AM
Madwick's Avatar
Madwick
recently i've notice i have a oil drip overnight about 2" in diameter at most. yesterday i was at a stop light and noticed smoke coming from the hood scoop. when i parked i popped the hood to find and noticeable amount of oil on the turbo and around it.
where would i need to look to see what needs to be replaced or adjusted?
Old Jan 29, 2013 | 05:58 AM
Braminator's Avatar
Braminator
A common problem that on the Gen 2 MINI is with the oil lines that feed the turbo on the S models. What happens is the banjo fitting on the feed line fails allowing oil to leak onto the turbo. So check the oil line that feeds the turbo. Read this thread https://www.northamericanmotoring.co...s-leaking.html
Old Jan 29, 2013 | 09:47 AM
Madwick's Avatar
Madwick
so that helped. def noticing that the oil is coming from the banjo fittings. thanks for the help!
Old Jan 29, 2013 | 10:08 AM
Braminator's Avatar
Braminator
No problem. Keep us posted. Good luck
Old Jan 29, 2013 | 03:17 PM
DogT's Avatar
DogT
Yeah, just open your wallet.
Old Jan 29, 2013 | 05:48 PM
COOP310's Avatar
COOP310
There is a veyt useful thread on this subject titled 'HELP!...Turbo Oil Feed line is leaking!'
Old Jan 29, 2013 | 05:54 PM
Braminator's Avatar
Braminator
Here ya go
Old Feb 28, 2013 | 10:24 AM
Madwick's Avatar
Madwick
yep! the banjo fitting has come loose and is now leaking oil on the top of the turbo. the oil burns while driving and smoke comes out as soon as i stop. i would like to make a custom oil feed line from braided line and 2 banjo fittings like the upgraded turbo kits include. any idea?
Old Feb 28, 2013 | 02:20 PM
ashchuckton's Avatar
ashchuckton
Hot oil on an even hotter turbo is the recipe for disaster. Best fix it soon.
Here you go http://www.detroittuned.com/detroit-...urbo-oil-line/
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
Gil-galad
Eastern Iowa MINIs
17
Sep 12, 2015 07:13 AM
WayMotorWorks
Aug 25, 2015 10:01 PM
dirtyscarab
Aug 23, 2015 07:50 PM
