Will any of these tires work with 17in wheels
I was eyeing some Rotiform wheels and was wondering if any of these http://www.nokiantires.com/tyre?id=1...me=Nokian+WRG2 in run flat would work with them on a Cooper S.
On a stock R56, the 205/50/17 RFTs should be fine on the Rotiforms. Keep in mind, the tire will be a bit taller than stock. Meaning your speedo will read slower than your actual speed.
Also, the wheels will stick out quite a bit. 17x8 ET30 on stock height will make it look like a 4x4.
But if you dont care about that, then by all means, go for it.
Just find a tire with the OEM size 205/45/17.
As for not sticking out, you will need to find another wheel.
You probably want something along the lines of OEM fitment. 17x7 or 17x7.5 is what most people have.
Go on tirerack to see which wheels you like. Tirerack will pretty much guarantee a good fitment on your car.
Rotiforms are a somewhat aggressively sized for Minis just so you know. You will also want to make sure to get et30 rather then et20 to keep them sticking out of the fenders as much as possible. A 205/45/17 would be most ideal for matching speedo and stick out minimally.
Mini'mon
Aug 16, 2015 04:15 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
