R55 Oil light flashed??
Old Jan 24, 2013 | 03:23 PM
Krhineheart's Avatar
Krhineheart
Oil light flashed??
I have only had my 2009 Clubman since June, 2012. I had an oil change done in October and my mechanic (a mini guy) told me to ignore the ODC and change it every 5000 miles. It has only been 3000 and today while driving to work, an oil indicator flashed for 1-2 seconds and then was gone. I don't even think it was the full three alert chimes.... I drive less than 200 miles a week and most of it is slow boring driving. Has anyone ever had this happen?
Old Jan 24, 2013 | 03:28 PM
Braminator's Avatar
Braminator
You are low on oil. Go check it.
I agree but you still should check it every 1000 miles IMO.
Old Jan 28, 2013 | 02:09 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
+1 Bradminator
Old Jan 28, 2013 | 10:36 AM
CA94960's Avatar
CA94960
I check the oil on my wife's MINI every week - it only takes a minute to do.
Old Feb 4, 2013 | 03:07 PM
ashchuckton's Avatar
ashchuckton
When you see that oil light you are damaging the engine, stop the car & check the oil. As has been said at least once a week. Check & add oil as needed you'll most likely be OK.
Old Feb 22, 2013 | 02:55 PM
Oreod's Avatar
Oreod
I have had this happen on my 2011 5 different times. It is now at the dealership and they are replacing "sensors and wiring harness". It is most definitely not an issue of low oil in my case. It always happens at highway speed and stays on for about 1 second and 1 chime. The way Mini is approaching the problem I would say (1) they have seen it before and know what to do or (2) they don't have a clue. No grey area here.
I will keep you posted.
gary
Old Feb 22, 2013 | 05:40 PM
Fly'n Brick's Avatar
Fly'n Brick
The more fiddly bits they add to a motor the more fiddly bits there are to cause problems actual or perceived. Idiot lights are no substitue for proactive attention to the operating systems. An idiot light can as easily flash erroniously when there is no problem as it can NOT flash when there is one.
sevin
May 2, 2026 06:11 AM
Alkaidovich
Jan 30, 2021 01:35 AM
Dec 23, 2015 10:36 AM
oldkid6
Aug 11, 2015 08:13 PM
