R56 Emergency help! Can push start!
Old Jan 15, 2013 | 06:10 PM
Mini0n's Avatar
Mini0n
Im in The car got my brakes done earlier today and im tryn to start the car and the brake wont go down so i cant push start! Im not home help me out asap!
Old Jan 15, 2013 | 06:26 PM
alpinamike's Avatar
alpinamike
Make sure you have the car in gear . Most likely the rear e-brake is stuck . They can sometimes rust and then when you pull on the e brake and then let off the cable does not retract. Put the car in gear if manual . Park if auto , release the e brake then tap the where the cable connects to rear caliper towards the bottom. When you drive your MINI in the salt from winter it will happen. After your done I would replace the cables.
Sound like problem?
Old Jan 15, 2013 | 06:29 PM
leaf_fan_1988's Avatar
leaf_fan_1988
Pop the hood and open the brake fluid reservoir. That should create a vent so you can release pressure on the brake lines.
I don't know man, never heard of this kind of problem. Should have gotten a first Gen, we don't have those issues.
Old Jan 15, 2013 | 06:33 PM
Mini0n's Avatar
Mini0n
im gonna try that but knowing my luck it probably wont be it
Old Jan 15, 2013 | 06:37 PM
Braminator's Avatar
Braminator
Doubt thats gonna do it. You will need to jack the car up and release the pressure through the calipers.
Old Jan 15, 2013 | 06:38 PM
leaf_fan_1988
If it does, let me know. I'll have another beer to celebrate.
That's got to be it though. I don't think there's any electrical issue that would prevent the brake pedal from being pressed. It has to be mechanical... Or something frozen.
Braminator's Avatar
Braminator
maybe this will help
http://www.pelicanparts.com/techarti...ing_Brakes.htm
Old Jan 15, 2013 | 06:45 PM
Mini0n's Avatar
Mini0n
I just got my brakes and rotors done this morning maybe they are too tight.. But i turned the car on 4 time between when thu got installed and now The awesome thing is my mechanic is only 6 blocks away... At it is 944 pm! Not 6 i wish!
Old Jan 15, 2013 | 06:48 PM
Braminator's Avatar
Braminator
I will bet they just need to be bled.
Old Jan 15, 2013 | 06:55 PM
leaf_fan_1988
Check your fuses?
Did you try pumping the brake pedal (as hard as possible) when you took the brake fluid cap off? It definetly won't bleed your brakes, but it's your only bet to attempt to get the pedal to press past all that pressure.
Old Jan 15, 2013 | 06:57 PM
Mini0n's Avatar
Mini0n
i dont even know how to do that, argh! Or bleed it ! so fustrating and its friggin cold... And that mini jack does not look stable lol my boyfriend used his his car amd it slipped... Yikes!
Old Jan 15, 2013 | 07:01 PM
Mini0n's Avatar
Mini0n
Originally Posted by leaf_fan_1988
Check your fuses?
the more i pumped the the more stiff it became,, that would work on a manual car
Old Jan 15, 2013 | 07:07 PM
kromdom's Avatar
kromdom
do you have roadside assistance with your car insurance?
Old Jan 15, 2013 | 07:12 PM
Braminator's Avatar
Braminator
Read this.
Old Jan 15, 2013 | 07:19 PM
Mini0n's Avatar
Mini0n
I do i forgot about that
Old Jan 15, 2013 | 07:22 PM
Braminator's Avatar
Braminator
Where in NY are you? Maybe another NAM can help.
Old Jan 15, 2013 | 07:29 PM
leaf_fan_1988
Wait. If you can press on the pedal enough to notice it getting stiffer that means your fluid and lines are fine.
You have a broken or brake switch or sensor or whatever it is. The thing that tells the ecu that you're brakes are pressed.
You can verify this by checking if you're brake lights are coming on when you step on the pedal.
...I think. Should have gotten a manual 1st Gen aka a real MINI lol.
Old Jan 15, 2013 | 07:34 PM
Mini0n's Avatar
Mini0n
Im in queens ny, i read the article and im too muh of a noob i will probably mess it up , mind you i never jacked up my car. I know the process just havent, plus my car is on a busy street, luckly street cleaning in on friday!
Old Jan 15, 2013 | 07:35 PM
Mini0n's Avatar
Mini0n
Gosh if i was far from home i would have gotten someone on craigslist! lol
Old Jan 15, 2013 | 07:38 PM
Mini0n's Avatar
Mini0n
Im learning manual thank you very much but it has been put on hold i cannot reach the bmw 330ci clutch without cramping my legs, so how do you think that damage happened ? Did the mechanic accidently mess it up? Or is it just a big coincidence?
Old Jan 15, 2013 | 07:47 PM
leaf_fan_1988
It could just be a coincidence and/or a faulty piece of electrical equipment, how often does anyone hear of this happening?
Old Jan 15, 2013 | 07:51 PM
leaf_fan_1988
And when I taught myself how to drive standard on my Mini the stiff BMW clutch cramped up my leg(s) often. And I'm a tall, athletic guy, but I sit at a desk a lot so my muscles had gotten lazy.
Old Jan 15, 2013 | 07:59 PM
Mini0n's Avatar
Mini0n
i cant press the brake pedal down at all its very slight, so the brake light doesnt engage
Old Jan 15, 2013 | 08:10 PM
phxsteele's Avatar
phxsteele
Not sure about minis but most auto transmission cars can be started in neutral. Try releasing the parking brake if you have it pulled, turn the key on and step on the brake pedal to shift to neutral and start.
Old Jan 15, 2013 | 08:12 PM
leaf_fan_1988
Unless someone else come's up with a better answer, this is all your stuck with. You're going to have to tow it to the dealer or your mechanic to get a proper diagnosis.
Try this last band aid solution. If you were to blow a fuse that wouldn't let you move the shifter out of park, because it can't sense the brake pedal, there is a button you'd press, usually hidden under a tab you have to pop off on the shift boot area.
Try pressing that and pushing the start button. The engine cycle should release the brake pedal. If it doesn't realease the pedal, please don't be stupid enough to drive without brakes.
