R50/53 Engine Stutter
Old Jan 15, 2013 | 03:22 PM
rupta's Avatar
rupta
Engine Stutter
I have a 2003 MINI (CVT, non-S), and I've been experiencing stutters with the engine in the following circumstances.
- When coming to a hard stop
- When shifting gears from reverse to drive
The entire car shakes a bit and the RPM fluctuates. Any idea what could cause this problem?
Thanks!
Old Jan 15, 2013 | 03:24 PM
Miniman s's Avatar
Miniman s
Could either be the transmission or your mounts. Have you had your transmission drained and refilled? When was the last time you did engine mounts? How many miles are on the vehicle?
Old Jan 15, 2013 | 03:32 PM
rupta's Avatar
rupta
The car has 87K on it. The engine mounts were replaced around 60K. I'll have to check when the transmission fluid was replaced. I know that I have replaced it at least once, when my CVT was serviced.
Old Jan 15, 2013 | 05:08 PM
Miniman s's Avatar
Miniman s
The shutter between shifting you described is it limited to the engine or the whole car? Does the whole car shudder like it had just been hit?
Old Jan 15, 2013 | 06:16 PM
rupta's Avatar
rupta
I'm not quite sure where it is originating (engine or the transmission), but it would shake the entire body.
Old Jan 15, 2013 | 06:29 PM
Miniman s's Avatar
Miniman s
I'm thinking its the transmission. If your lucky a drain and refill will save it. Worst case scenario you will need to decide how much you like your MINI.
Old Jan 15, 2013 | 10:26 PM
Tinythumb's Avatar
Tinythumb
Tough shot but it may need a driver save memory reset so the transmission can relearn for a short time and driver habits. It helped me on a little rpm drop kind of like yours but stopped the yo-yo effect from 5-10mph. Made my transmission work alot smoother and better when i did this simple reset.
Resetting the memory for it is in the display panel through the special menu from holding trip button and turning key to position 1, im sure u know? If not can please someone post link?
Hoped this helped!
Old Jan 16, 2013 | 12:00 PM
rupta's Avatar
rupta
Hi Tinythumb,
That sounds easy enough to give it a try!
Thanks!
Old Jan 16, 2013 | 12:53 PM
Tinythumb's Avatar
Tinythumb
Originally Posted by rupta
Hi Tinythumb,
Thanks!
Cool i hope so, it Will help, let me know then!
Old Jan 17, 2013 | 04:11 PM
rupta's Avatar
rupta
Did the ECS reset last night. So far so good, but I'll know more after a weekend of driving.
Old Jan 17, 2013 | 04:33 PM
Tinythumb's Avatar
Tinythumb
Yeah that reset will help, and sounds like it did! It did on mine hehe
Old Jan 19, 2013 | 05:37 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
If not try the ICM. Clean and refit.
Old Jan 23, 2013 | 09:09 AM
rupta's Avatar
rupta
Thanks. I'm not familiar with the ICM, but I'll look it up.
Old Jan 23, 2013 | 09:36 AM
Tinythumb's Avatar
Tinythumb
Cool man, seems like ur doing good.
Btw what is icm n a how to?
David.R53
Sep 1, 2015 06:49 PM
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
