Crank case vent and oil leak
Old Jan 14, 2013 | 02:11 AM
sun2on99's Avatar
sun2on99
Hi guy, I just wondering what is going on with my mini. There has always been some oil leaking from the spark plugs area or under the crank case vent pipe. Anyone knows what the problem is or how to fix it? The crank case vent pipe seems to be loose and very easy to unplug, I circled it in the photo. Is it installed properly? Is it meant to be inserted further in and clip onto something?
I've had my car serviced about 4 months ago and topped up with 5L of engine oil, but last week I checked the dip stick, it was at "low" level. I'm worrying that my engine is constantly running without engine oil and hence that explains the very hot bonnet. Anyone can give me some pointers? Thanks.
Old Jan 14, 2013 | 04:23 AM
Braminator's Avatar
Braminator
Take the cover off and make sure the clamp is tight or replace it with a new one.
Old Jan 14, 2013 | 12:21 PM
sun2on99's Avatar
sun2on99
Thanks. Are you referring to the top cover only where the logo sits? I tried to remove it but its very tight and couldn't even move a bit. How do u actually remove the cover?
Old Jan 14, 2013 | 12:47 PM
DneprDave's Avatar
DneprDave
There is a clip that holds the hose onto the head cover, you shouldn't be able to pull the hose off of the cover, without removing the clip.
Dave
Old Jan 14, 2013 | 12:49 PM
Braminator's Avatar
Braminator
I just did some searching and this is what I can up with. I am sure it is not what you want to see or hear though.
https://www.northamericanmotoring.co...pcv-valve.html
Old Jan 14, 2013 | 12:53 PM
sun2on99's Avatar
sun2on99
Thanks Dave. Where is that clip? Is it visible from the surface or hidden under the cover? Mine is an euro spec, not sure if that makes a different? Do u remove the cover in order to get to the clip or can the clip be pulled out directly without the need to remove the cover first?
Old Jan 14, 2013 | 01:10 PM
sun2on99's Avatar
sun2on99
Thanks Braminator. That's horrible and I'm sure my dealer here in Sydney won't even give a shxx but overcharge me for replacement.
Old Jan 14, 2013 | 01:15 PM
Braminator's Avatar
Braminator
Keep us posted.
Old Jan 14, 2013 | 02:08 PM
MNIPWR's Avatar
MNIPWR
I can tell from the picture that you are indeed missing the clip. It would slide into the plastic guides on either side of the hose. Also 4 months between oil checks is insane.
Old Jan 15, 2013 | 09:11 AM
Yakatak's Avatar
Yakatak
You need to install an aftermarket turbo heat shield to keep the bonnet cooler. I have, and can recommend, the one from NM Engineering.
Old Jan 15, 2013 | 12:18 PM
sun2on99's Avatar
sun2on99
Thanks Yakstak, but does heat shield helps oil leak? I still don't have full understanding of how the heat shield works, the heat is trapped under the bonnet, and adding the heat shield will further confine the hot air to around the turbo and doesn't mean it will be hotter for the turbo?
Old Jan 15, 2013 | 12:48 PM
DneprDave's Avatar
DneprDave
I think Yakstack posted on the wrong forum.
You are right, a heat shield won't help stop an oil leak. It's to keep the plastic hood scoop from melting.
Dave
Old Jan 15, 2013 | 09:31 PM
Yakatak's Avatar
Yakatak
Sun2on99 commented on his "very hot bonnet". That's why I suggested the heat shield. No, it doesn't do anything for an oil leak. The NM and M7 heat shields are mostly flat and simply shield the bonnet from radiant heat from the turbo. They don't trap much heat at all (unlike a turbo wrap), and for what little heat they do trap, like the Honey Badger,.. turbo don't care.
Jon
Old Jan 15, 2013 | 09:34 PM
MNIPWR's Avatar
MNIPWR
Valve cover cares.
woodstudio
Mar 15, 2020 08:28 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
M7Speed
Aug 6, 2015 01:48 PM
