R56 What is missing?
Old Jan 13, 2013 | 12:27 PM
MCS_2008's Avatar
MCS_2008
What is missing?
So I took my car in to get a few gaskets replaced and came out with a huge boost leak. So I did some investigating and found the culprit. Seems like the mechanic left something out. What is suppose to connect the 2 plastic pipes to the right and below the air box?
Attached Thumbnails What is missing?-image-2976499046.jpg   What is missing?-image-289801651.jpg   What is missing?-image-103863995.jpg
Old Jan 13, 2013 | 01:50 PM
gregsmini's Avatar
gregsmini
I took a look at my Mini and I don't see anything missing but...the pipes are not put together correctly. It is easiest to see in your third picture. The inner pipe needs to be pushed into the outer pipe. The inner pipe has a triangular **** on it. The pipe needs to be inserted so that the *** is against the other pipe. I would say it needs to be pushed together another 3/4 - 1".
Now I'm not saying something isn't missing on the other end, at the front of the car. That's all I can see. If you can't get the pipes to go together, you may have something missing or not assembled correctly on the other end of the pipe.
Old Jan 13, 2013 | 02:23 PM
MCS_2008's Avatar
MCS_2008
Yea I've tried putting them together but it just doesn't line up correctly... I might just have to take it back to the shop..
Old Jan 13, 2013 | 02:58 PM
MCS_2008's Avatar
MCS_2008
Ok I got it to connect properly, but there is still either a boost leak or some other unexplained loss of power.
Old Jan 14, 2013 | 07:14 AM
bluefox280's Avatar
bluefox280
Being that pipe connection you're referring to in on the not-pressurized side of the intake, its definitely not your cause of loss of boost.
You need to pressure check the rest of the system and check for leaks downstream of the turbocharger compressor.
- Erik
OutMotoring
Nov 16, 2015 07:04 AM
simo711
Oct 1, 2015 05:36 AM
tristanwelch95
Sep 30, 2015 08:58 AM
BackroadRunner
Sep 29, 2015 08:06 PM
smbmkay
Sep 11, 2015 09:45 AM
