Fault codes HELP!!
Old Jan 13, 2013 | 07:41 AM
jmgpr7's Avatar
jmgpr7
Fault codes HELP!!
Hey , my r56 S was running perfect , yesterday i was driving at 50 mhp a suddenly the check engine turn ON!! 2 week ago i added a downpipe.
this are the codes:
P2270
P2A74
P2A7F
HELP plz
Old Jan 13, 2013 | 07:55 AM
Braminator's Avatar
Braminator
Your code is P2270 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 2).
The other 2
P2A74
P2A7F
maybe someone else will know as I don't see them listed anywhere.
you don't mention if it is a catless DP. If it is with any catless downpipe you will get a check engine light, but you can bypass it with the accessport.
Old Jan 13, 2013 | 08:05 AM
jmgpr7's Avatar
jmgpr7
The other 2
P2A74
P2A7F
thanks, yes its a catless DP but i feel the car no having full strength. and sound wierd. i cant find the other 2 codes.
Old Jan 14, 2013 | 08:24 PM
bluefox280's Avatar
bluefox280
Originally Posted by jmgpr7
I cant find the other 2 codes.
What type of scanner did you use?
Because some generic OBDII scanners provide misleading P-codes as the programming doesn't match to the MINI's on-board diagnostics protocol.
- Erik
Old Jan 15, 2013 | 07:09 AM
jmgpr7's Avatar
jmgpr7
- Erik
i used a COBB accessport to scan the R56. But yesterday, when i started the mini in front of the mechanic the CEL turn off, he scand it and there were no fault codes!!!
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
ShadyCoop
Sep 20, 2015 08:57 AM
Enjoytheride
Sep 17, 2015 12:10 PM
sirfrank
Sep 11, 2015 01:36 PM
