Issues Shifting into Second
First off, I have posted about this in a similar thread as well as talked about it in an intro thread that I started. Not trying to spam, just trying to get the question noticed.
Just got an '02 R50 with just under 75k on the clock. Had it checked out by mini of Boston and essentially got the green light (seller did a few repairs but I won't get into that in detail here - related to exhaust).
One issue that I had with the car, and that Mini of Boston was made aware of, is shifting into second was a bit... soft. I don't know how else to explain it. It doesn't grind. It just doesn't pop into second 100% of the times when I pull the shifter down into place. Sometimes it takes a second or third try. Conversely, if I hold it in place (the lever) while lifting my foot off the clutch it sticks in smoothly. The mechanic at Mini of Boston said he had seen this before. In fact, he drive an '04 and it does the same thing. He hasn't bothered to mess with it, but said if I were to do it, gear linkage is where he would look.
Just looking for a bit of input. I am a complete novice when it comes to car repairs, but if there are any diagnostics I could possibly run myself ad perhaps even fix the issue, that would be awesome. Obviously not a deal breaker; i bought the car well below book value and would like to get the shifting at 100% unless it is terribly cost prohibitive.
This community seems awesome. Thanks in advance!
Keep on motoring!
Keep on motoring!
Sixty-seven views! No ideas/opinions?!
I read to take a look under the air box, though I am not sure what to look for. I am confident I can safely remove the airbox in the daylight tomorrow. I guess the gear linkage terminates there? The dealer made it sound like swapping a gear linkage required dropping the exhaust and getting under the car, so I am not sure why I am reading to look under the air box, but I guess it wouldn't hurt. Nothing to lose but time!
Find another mechanic from a different shop and see what they say. If diagnosis is same as the Mini mechanic, then may be safe to say the gear linkage is indeed the culprit???
Here in MA we are required to have a safety check done by a garage (basically check for things that the police might pull you over for such as busted tail lights, blinkers, etc.), and we had that done today. I asked the mech, and he said that is what it felt like, but without taking things apart, he wouldn't know for sure. Was going to take the airbox out today but it was raining (we don't have a garage) so I have to wait for clear weather. Should be able to get to it tomorrow maybe.
I... wouldn't know what to look for. Basically been reading about issues/fixes online and dealing with it from there. I fixed the creaky steering today. It's obviously not a heavily tichnically involving job, but removing a steering wheel and trim is far more than I have ever done on a vehicle before. As cheap as we bought it, I am much more willing to poke around and learn with this car.
The Mini dealership where I had it looked at didn't mention anything. Is this something I can easily look at myself?
I would suspect that the shift cable is out of adjustment. With the car not running have someone try to put it into 2nd, 4th and 6th. Watch where the shifter cables attach to a linkage at the transmission.
Does it shift smoothly into 2nd when the car is off?
I was speaking about the airbox before... am I having someone shift and looking under the airbox? If not, where, specifically am I looking?
It does shift smoothly into second with the car off. Truth be told, 95% of the time it shifts into second smoothly when the car is on too. The trouble is when making a sharp turn, specifically left. I would say it has issues well over 50% of the time when making said turn.
Open this file and goto page 60-69. It will show the linkage
http://rapidshare.com/files/12047928...ansmission.pdf
Thanks!
Looks like it's actually going to be under the battery (for the cooper models) and under the airbox (for the S models). This information potentially helps a lot because I'd be scratching my head looking for something that isn't there!
Would you happen to have the rest/more of the manuals? I'd like illustrations of how to remove the battery compartment if at all possible.
Thanks a million again for your help thus far.
I dont have one with the pics but you can read this.
http://rapidshare.com/files/2654406267/BATTERY.pdf
Going to wait until tomorrow when my wife is able to help shift the vehicle for me. No sense in removing everything before I have a helper. Will report here.
I still haven't gotten around to doing this... been rainy AND the wife kept poo-pooing the idea. She has the next two days off and promised she would help with the extremely labor intensive task if shifting the car's gears while I look under the battery and see what I can see.
I still kind of fear that I won't know what I am looking at. I plan to record some video and link to it here so that people who actually know wha they are doing might be able to help me out.
EDIT: For anyone following this thread (now or in the future), I found this link (from pelicanparts) with some illustrations. Seems both the airbox and the battery compartment need removal, as JUST the battery compartment cannot come out.
Alright my friends. Finally got around to taking a look. Truth be told, not sure what I was looking at... so I took some video. All help thus far (and of course in the future) is appreciated!
That ends up meaning new transmission right?
