R56 Are you serious?
Old Jan 7, 2013 | 05:29 PM
xSFx MISFIT's Avatar
xSFx MISFIT
Are you serious?
Is this an outrageous quote? Or is this an average price I'm looking at having to pay for install bc it seems ridiculously steep to me. Please give me some feed back.
Old Jan 7, 2013 | 05:34 PM
miles_miles7's Avatar
miles_miles7
That is just way up there. Just take it to a local shop.
Minus the alignment and cornering balancing I estimated about 4 hours plus or minus.
Old Jan 7, 2013 | 05:36 PM
madmaxxed's Avatar
madmaxxed
Wow! Save the money and do it yourself. Simple bolt on items.
Old Jan 7, 2013 | 05:41 PM
GFMINI's Avatar
GFMINI
Seems reasonable for "dealer" pricing. However, there is nothing on your list a local reputable garage mechanic in your area can't handle for a fraction of the price. Doesn't even need to be a MINI guy, springs and swaybars are pretty much universal knowledge.
Old Jan 7, 2013 | 05:45 PM
Braminator's Avatar
Braminator
Exactly, or find another shop to compare prices.
Old Jan 7, 2013 | 05:56 PM
dannyhavok's Avatar
dannyhavok
I had a line on the sports suspension package (sway bar, springs.) really cheap here in the marketplace. For kicks I asked the dealership how much to install, it was over $2k if I recall.
I am not a mechanically inclined guy, so when I wanted coilovers/control arms I took it to the shop that does my wheel and tire stuff. ~$500 including mounting and balancing my summer rubber.
Old Jan 7, 2013 | 05:58 PM
xSFx MISFIT
Ya this isn't a dealership giving me that quote, was a local mechanic shop.
Old Jan 7, 2013 | 06:00 PM
GFMINI's Avatar
GFMINI
If that was from an independent mechanic, your area must be suffering for work, because they obviously are trying to pay the bills on your dime. Find another shop ASAP. Or just find a guy that can set you up on the side when he is not at work (cash, 100% in his pocket, under the table)
Old Jan 7, 2013 | 06:08 PM
xSFx MISFIT
Yes an independent mechanic and that quote came with an email saying they included a 10% discount. Haha
Old Jan 7, 2013 | 06:14 PM
miles_miles7
Dang, i was just u there in Palo Alto. I could have hook you up for a six pack.
Its not hard doing what you needed done. Get on You Tube for some idea how how to do the swap/install.
Old Jan 7, 2013 | 06:16 PM
xSFx MISFIT
Well come back up and I'll give you a 24pack instead
Old Jan 7, 2013 | 06:21 PM
miles_miles7
I'm over 500 miles away from you bud
Old Jan 7, 2013 | 06:33 PM
xSFx MISFIT
Well if there is any NorCal people reading this, please reply with reliable shops and possible pricing because I got no tools to do this myself.
Old Jan 7, 2013 | 07:52 PM
richardsperry's Avatar
richardsperry
Do you all have any idea how shops come up with pricing? It's called flat rate. They look up the job in a book or on the web. Every job is listed with the # of hours it gets billed at. # of hours times shop rate equals what they bill you for, even if it takes less time.
Anyway, in reality, it should take 4 or 5 hrs all in. Maybe less if they know what they're doing.
Old Jan 7, 2013 | 08:11 PM
xSFx MISFIT
Alright we'll if that's the case why are there such vastly different quotes from different shops? Seeing how you know how all this pricing works, are you saying the quote I got is accurate to the supposed time it should take to install?
Old Jan 7, 2013 | 08:25 PM
Porthos's Avatar
Porthos
Damn if you were not so far away and could wait a couple of weeks I will buying coilovers and I could help you install yours and vice versa.
Old Jan 7, 2013 | 08:54 PM
xSFx MISFIT
I'm not in any hurry, where you located? I wouldn't mind gaining some mechanical knowledge.
Old Jan 7, 2013 | 08:57 PM
rkw's Avatar
rkw
Assuming you're in Discovery Bay as in your profile, two to consider are Edge Motorworks in Dublin and Bay Bridge Motors in Oakland. Both are very knowledgeable about MINI and have good reputations in the MINI community.
Old Jan 7, 2013 | 09:16 PM
Porthos's Avatar
Porthos
I am all the way in San Clemente, Ca.
Old Jan 7, 2013 | 09:55 PM
xSFx MISFIT
That estimate was from edge motorworks so they are a bit unreasonably priced for me, but I'll def. check out that other one, thanks for the reference
Old Jan 7, 2013 | 09:56 PM
xSFx MISFIT
Good time for a road trip, pch would be a fun mini ride.
Old Jan 7, 2013 | 10:07 PM
Porthos's Avatar
Porthos
Well order them up I will be ordering mine tomorrow.
Old Jan 7, 2013 | 10:40 PM
rkw's Avatar
rkw
I think the labor rate at Bay Bridge Motors would be similar to Edge Motorworks. Both are higher end independent shops but still much cheaper than the dealer.
Am I reading that right? $625 for coilover installation is reasonable. However the most expensive item is $820 for sway bar install? That should be the lowest item! There must be some mistake and you should ask them to verify it. Also ask them about hours of labor for each of the items.
Old Jan 7, 2013 | 10:47 PM
xSFx MISFIT
Ya that's what I thought too! You would think the sway bar would be an easier job, I did ask them about pricing and hours for labor and they responded by saying the charge based off recommended prices given by BMW/MINI, which I think is lame because wouldn't you just rather go to the dealer if they're going to chArge the same exact thing?
Old Jan 7, 2013 | 10:59 PM
Porthos's Avatar
Porthos
What coil overs did you get anyway?
