R56 Taking off the B pillar cover
Old Jan 6, 2013 | 11:16 PM
CarlosDMotor's Avatar
CarlosDMotor
Planning on taking off rear panel to get the speaker wire to my amp, and to do that you have to take off the b pillar panel, which has an airbag behind it. What precautions to make sure it doesnt go off?
Old Jan 6, 2013 | 11:20 PM
CarlosDMotor
One More Question
one other thing related to the amp-which fuse is good for the remote wire. I want one where it only runs when the engine is on. Would the headlight one be good, or is that too much current (40a)
Old Jan 6, 2013 | 11:49 PM
Samysonary's Avatar
Samysonary
It has been a while but for the B pillar cover removal you will need to pull out the ambient light cover. Careful pulling out the cover, they need to be pulled out straight. Then there is a screw (T20 I think) behind the cover that needs to be removed. Unplug the battery and you should be fine. The airbag comes from the roof so you should be fine.
I tapped into the voltage of the cigarette for the remote turn on. It only turns on when the car is turned 'On'.
Old Jan 6, 2013 | 11:52 PM
CarlosDMotor
Yeah I just found a screwdriver. I have an iphone charger that i took apart but im not sure how to wire it. I know that red goes into slot but im not sure what to do with the white (ground) wire
Old Jan 7, 2013 | 04:02 AM
countryboyshane's Avatar
countryboyshane
Any clean spot of metal on the car is fine for a ground connection.
sevin
May 2, 2026 06:11 AM
Kimolaoha
Jul 5, 2023 01:04 PM
Aug 19, 2015 09:12 AM
bctf1
Aug 6, 2015 12:55 PM
