R50/53 Airbag Light - Table 10 code 15: Firing Circuit, Head Airbag, Stage 2
Old Jan 6, 2013 | 10:45 AM
tom-nola's Avatar
tom-nola
[SIZE=2]Greetings - Thanks in advance for any help.
Trying to reset my airbag light on a 2003 Mini Cooper
Bought the scanner and it revealed the code:
Would not reset, I looked under my seat to verify blue and yellow connectors are firmly connected. With the device indicating a code in the Head Airbag, I believe it is something wrong with my main airbag in the steering wheel, hopefully just a loose connection. Does anyone have any experience with this?
btw: What is Stage 1 vs Stage 2?
(Here is a listing of all codes: autonumen.com/uploadfiles/20080602004454526.pdf
Thanks again, I'll keep this updated with how I fix this...
[/SIZE]
Old Jan 7, 2013 | 05:39 PM
tom-nola's Avatar
tom-nola
Solved
Fixed it today. I took off the airbag, steering wheel, and clock spring - and noticed the yellow connector was not connected. I connected it, then put it all together. Cleared the code and it did not come back on.
There is a youtube video which shows how to take off the airbag and steering wheel.
To remove the clock spring, remove the two screws underneath the steering column (torx T27) and push the cover down on the front side - you don't have to take it off. There are 3 screws connecting the clock spring (T20 I believe).
So 7 screws total, will take 20 minutes to do.
Please take proper precautions with your airbag, including disconnecting the battery, waiting 10 minutes, and also unplugging all/any electronics plugged into any cigarette lighter/adapter, etc...
I attached two pictures showing the clock spring front and back.
Hope this info can help you.
Attached Thumbnails Airbag Light - Table 10 code 15: Firing Circuit, Head Airbag, Stage 2-photo-airbag1.jpg   Airbag Light - Table 10 code 15: Firing Circuit, Head Airbag, Stage 2-photo-airbag2.jpg
Old Jan 7, 2013 | 05:45 PM
miles_miles7's Avatar
miles_miles7
How much did you score your airbag scanner?
Glad you fixed your issue.
Old Jan 7, 2013 | 05:46 PM
Braminator's Avatar
Braminator
Great job. Glad it all worked out for you.
Old Jan 7, 2013 | 06:03 PM
tom-nola's Avatar
tom-nola
I think i got a little ripped off on mine, got it for 60 pounds - which is about $100...
I say this link for $25: {deleted due to suspect site}
Last edited by tom-nola; Jan 8, 2013 at 04:55 AM. Reason: bad grammar and link to suspect site
Old Jan 7, 2013 | 06:04 PM
tom-nola's Avatar
tom-nola
(saw) this link....
Old Jan 7, 2013 | 07:01 PM
ZippyNH's Avatar
ZippyNH
A review of the website Alibaba.com... BEWARE 90% of so called suppliers are frauds. U will get scammed one ...
the first link when I searched on google for the website and review....
Old Jan 7, 2013 | 07:02 PM
ZippyNH's Avatar
ZippyNH
Alibaba.com Website Reviews - Page 1 | SiteJabber
www.sitejabber.com/reviews/www.alibaba.comShare
Rating: 1.5 - 25 reviews
25 reviews of Alibaba.com "Piece of S$#IT want to lose your money? Go ahead and order, you have been warned..."
Next link on a google search for said site and review...
Old Jan 7, 2013 | 07:07 PM
ZippyNH's Avatar
ZippyNH
You have been warned....
MAYBE there is a Seller on that site that is OK, but does not look good...
An Entire site dedicated to the "scam site above".
[URL=http://alibabascam.com/[/URL]
Old Jan 8, 2013 | 04:52 AM
tom-nola's Avatar
tom-nola
holy smokes... sorry for the bad link!
let me see if I can delete that so no one gets taken advantage of.
Teh
Jun 13, 2018 02:59 PM
one73ronin
Aug 19, 2015 12:36 PM
quality_sound
Aug 7, 2015 09:36 AM
MIminiclubman
Aug 5, 2015 09:14 PM
