R50/53 Mannual transmission oil change different with/without LSD?
Old Jan 2, 2013 | 04:53 PM
opticspen's Avatar
opticspen
I just don't know if my R53 has LSD (2005 model and has 40k miles only), and about to do some oil change and want to change the transmission oil too.
is there any difference for one with LSD or without it? ie, the total capacity of tranny oil, or any procedure difference?
thanks
Old Jan 2, 2013 | 05:53 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've been using the Redline MTL. It takes 2 liters to fill the trans
Old Jan 2, 2013 | 06:16 PM
opticspen's Avatar
opticspen
does it matters with/without LSD models, is there any difference.
Old Jan 2, 2013 | 08:15 PM
cristo's Avatar
cristo
Alliance Member
For R53 manual transmissions:
Redline MTL or Texaco MTF-94 for Getrag 6 speed with LSD (or without LSD before 7/2004),
Redline D6 or BMW-MTF-LT-3 for Getrag 6 speed without LSD after 7/2004
Old Jan 2, 2013 | 08:19 PM
opticspen's Avatar
opticspen
....damn it
how can i know I have LSD or not, tried call mini dealer, very hard to get call answered, always long waiting.
Old Jan 2, 2013 | 08:20 PM
opticspen's Avatar
opticspen
wait a minutes, the Redline D6 is for automatic transmission, it's ATF
--update
I just goggled and find out what you said seems right, I'll be contacting dealer to confirm, thanks a lot! all the DIY shows using redline MTL, which is really confusing and misleading.
thanks for the good inputs.
Old Jan 2, 2013 | 11:07 PM
Kdelder's Avatar
Kdelder
So.... How can one tell if you have a factory LSD or not?
Old Jan 2, 2013 | 11:18 PM
opticspen's Avatar
opticspen
I had someone help to run a VIN# for me and see if can get some clue
otherwise the official way is to ask Mini USA
my car shows it manufactured in 2004 12, so it's highly possible it does not have LSD, but I will confirm tomorrow thru Mini USA
thanks!
Old Jan 3, 2013 | 02:38 PM
Cadenza's Avatar
Cadenza
Just call your dealer's service department and ask them to run your VIN#.
Old Jan 3, 2013 | 04:32 PM
opticspen's Avatar
opticspen
my car manufactured at 2004 12, so it's likely without LSD, I run the VIN# in realOEM.com
am i able to count on this?
Old Jan 3, 2013 | 04:50 PM
opticspen's Avatar
opticspen
BTW, I bought both redline MTL and Royal Purple Synchromax for safe
after confirm with dealer, I will send one back.
confirmed with dealer, the listed options has no LSD listed.
and I would use synchromax, MTL is too thick for it and not good for cold start, I only have problem when car is cold now, very hard for 1st gear and reverse gear. and some notching from 1st to 2nd gear.
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
panerai21
Aug 18, 2015 02:15 PM
ludedude
Aug 10, 2015 07:16 PM
