R55 Mood lighting
Old Jan 1, 2013 | 11:15 PM
Hazzard01's Avatar
Hazzard01
Does the 08' clubman have mood lighting on the third door B-post?
Thx
Old Jan 8, 2013 | 04:21 PM
schatzy62's Avatar
schatzy62
Yes it should.
Old Jan 9, 2013 | 04:57 AM
yetti96's Avatar
yetti96
Well to clarify it is on the 3rd (club) door, but I am not sure if it technically is the B post because it is a part of the door. But where it is on a normal R56, right above the seat belt is the the same. Hopefully that helps clarify and not making it more confusing.
Old Jan 9, 2013 | 12:56 PM
minicooper1985's Avatar
minicooper1985
Yetti, that would be the B-pillar regardless. The car just has two on one side. But yes, I've seen some 08 models with the mood lighting, I believe.
Old Jan 9, 2013 | 12:58 PM
shipjumper's Avatar
shipjumper
I think its an option and wasn't standard...
Old Jan 14, 2013 | 04:27 PM
schatzy62's Avatar
schatzy62
On US Spec cars it is standard equipment and not an option. In some other countries it was an option.
Old Jan 14, 2013 | 11:20 PM
Hazzard01's Avatar
Hazzard01
I pulled the air bag cover off and did not see any sign of a light! I will double check and let you all know.
Old Jan 15, 2013 | 06:09 PM
schatzy62's Avatar
schatzy62
When you pull the air bag light cover off you will then need to take the screw out and remove the pillar cover to see anything. It is an LED module mounted on the back side of the pillar cover. May be just unplugged if they had to do an work on the club door they may not have reconnected it.
Old Jan 19, 2013 | 07:40 PM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
My 08 has mood lighting standard. Waterfall lights at front and one in pillar behind left front seat, one in Club door.
Old Jan 21, 2013 | 05:08 AM
shipjumper's Avatar
shipjumper
Is there an off switch, I like it, but just curious...
Old Jan 21, 2013 | 10:33 AM
MINIFatherFigure
No off as far as I have found, but they do dim with dash lights.
Old Feb 14, 2013 | 10:12 PM
Hazzard01's Avatar
Hazzard01
Found the issue! Took the panel off and found the led light hanging on the inside of the door. Plugged the light back in and the light works! Thanks for all the help!
Old Sep 1, 2013 | 08:15 PM
Bridget JB's Avatar
Bridget JB
Didja know that besides selecting the color of mood lighting you like, you can turn it on to rotating thru all the colors & repeating???
Old Sep 4, 2013 | 06:52 AM
Craig Curtis's Avatar
Craig Curtis
How?! Sounds very disco...
Old Sep 4, 2013 | 09:39 AM
Beachnmini's Avatar
Beachnmini
Just hold the toggle in the direction that changes colors, not the one that brightens/darkens, and it will keep going..
Old Sep 4, 2013 | 11:43 AM
Bridget JB's Avatar
Bridget JB
Basically, you just hold the button (I think it's toward you) until it starts changing colors on its own. Then let go. I think it's the 4th button from the left. It's awesome at night!!!
Old Sep 4, 2013 | 12:43 PM
yetti96's Avatar
yetti96
This will not work on pre-'11 cars. The '07-'10 R56 and '08-'10 R55 got just a few colors and no cycling. '11+ cars get a few more colors and you can cycle through the colors automatically.
Old Sep 6, 2013 | 07:26 PM
Letigre's Avatar
Letigre
Awww nutz.
blackie
Jan 18, 2017 09:56 PM
Aug 21, 2015 12:58 PM
Aug 19, 2015 12:51 PM
