Phone, Ipod, and AUX not working on my R56
Old Dec 27, 2012 | 09:26 PM
Min Minseok Song's Avatar
Min Minseok Song
Hey, I just became an owner of 09 MCS with conv. package.
But I recognized that the phone, ipod and aux connectivity doesn't work as I cannot get into those menu even though it has usb/aux ports under the center controls, and it shows the icon on the menu oddly (as the picture shown, the letter comes up, but there's -(dash) where icons supposed to be).
Here are some pics of the menu.
Is there any clue how I can solve this problem?
Attached Thumbnails Phone, Ipod, and AUX not working on my R56-img_0856.jpg   Phone, Ipod, and AUX not working on my R56-img_0854.jpg
Old Dec 28, 2012 | 06:52 AM
strobeyprobey's Avatar
strobeyprobey
The ULF module (bluetooth & USB) is not communicating with the head unit. There is a fiber optic ring (MOST BUS) between all of the entertainment devices (Changer, head unit, Bluetooth, HD tuner and sat tuner [if equiped]). So either the fiber optic ring has been broken or the module has gone bad.
BMW software diagnostics will have to be run to determine the cause of the failure. But make sure you check for any blown fuses, and if you are handy disconnect your battery for a half hour or so and reconnect.
If that does nothing you can (IMPORTANT: disconnect the battery first) and remove your driver side (left) seat and take a look at the connections on the ULF module inside the plastic compartment. Do not reconnect the battery until you plug the seat harness back in otherwise you will set an airbag light.
Old Dec 28, 2012 | 07:03 AM
Fastlane's Avatar
Fastlane
My stereo has done this and other strange things when the battery has run low or been disconnected during repair work. Try pulling the fuse for the stereo and the reinserting it after a few seconds. This will "reset" it in my experience. Just like with your home computer that gets buggy after a while, the stereo can get the same way and needs to restart. Try that first (or you could disconnect the battery temporarily) and see if that resolves the problem before you get too worried about faulty equipment.
If that does resolve your problem, you may have had a voltage drop at the battery....which may have been a fluke, or it might make me suspect that the battery might be starting to fail....just a possibility.
Old Dec 28, 2012 | 07:25 AM
strobeyprobey
Yes, I totally agree! Battery failure is also a likely cause for an issue like this.
Old Jan 7, 2013 | 08:34 AM
Katomangt's Avatar
Katomangt
Hello I just bought my 2008 R56 and had the same problem, I change the battery for a new one and still doesn't work the USB + Aux, Is there any cable that I should check to see if is plug on...or I have to take to the dealer??? Please help because I live to far for the nearby dealer.
Old Jun 2, 2013 | 08:40 PM
Min Minseok Song
Resetting the Stereo
I tried to reset the stereo on my R56 by disconnecting batteries for more than 3 hours. It seemed like the OBC was reset, however, every single setting on my stereo such as preset radio channels and bass/treble settings remained unchanged. Of course the Phone, USB and AUX still did not work. Is there any other way to fix it? or even reset the stereo?
Old Feb 17, 2014 | 11:11 AM
Mini_Men's Avatar
Mini_Men
Hello, someone has solved this?? I have exactly the same problem.
Please help!!
Old Apr 23, 2015 | 11:06 AM
fritzo's Avatar
fritzo
I'm having this same issue, so any solutions are appreciated! Trying to disconnect the battery tonight. Tried removing the fuses last night but no-go.
Old May 26, 2015 | 08:21 PM
JawKnee's Avatar
JawKnee
I just bought a used 08 MCS that came with just the Aux input and I'm having the same problem. Does anyone have a fix from doing something?
Old May 27, 2015 | 11:57 AM
fritzo's Avatar
fritzo
I pulled my Aux/USB module out (it just pops out by prying with a screwdriver). There's a set of cables it connects to, and from what I can gather there's something wrong with where those cables terminate. I haven't had a chance to investigate further, but any advice would be awesome.
Also verified all fuses to the radio are good.
Old May 28, 2015 | 04:42 AM
goldcountrymini's Avatar
goldcountrymini
This is probably a lame question, but how do you know if you have the convenience package? I have a 2011 MCS.
Old May 28, 2015 | 05:56 AM
scf's Avatar
scf
Go to this website, and enter the last 7 alphanumeric of your VIN, this will give you all of the packages your car left the factory with:
http://www.bmwarchive.org/vin/bmw-vin-decoder.html
Old May 30, 2015 | 09:03 PM
Wynnston's Avatar
Wynnston
I had a problem with a nasty knock off lightning to 30 pin adapter. I bought the genuine mini cable and got an apple lightning to 30 pin adapter and it worked fine after that. Are you using all genuine cables. I mean it shouldn't normally matter, but it's worth a try if you can find a friend with one.
Old Aug 12, 2015 | 10:19 AM
JawKnee's Avatar
JawKnee
Fritzo were you able to investigate further and find a solution to the problem that we are all having? Is there any relation to the module itself?
Old Jun 14, 2016 | 12:34 PM
JohnnyZenith's Avatar
JohnnyZenith
My Aux doesn't work either. 2008 R55 Cooper S. :(
Old Jun 24, 2016 | 05:13 AM
djenks76's Avatar
djenks76
My Aux has never worked properly in my 2008 r56. It only play bass and no treble. I've replaced the aux connector and no joy.
Old Apr 14, 2017 | 10:52 AM
SMracer's Avatar
SMracer
I have an 08 MCS and I have the same problem with my usb/aux port. My Y adapter works on other devices and I also swapped out the usb/aux port with a new one and no joy. I am thinking I need to replace cable that runs from radio to usb/aux port. About $90. Has anyone tried this fix?
Old Nov 25, 2017 | 10:12 AM
1973party's Avatar
1973party
Hi, I had this issue on my 2008 MCS and found that one of the fibre optic connectors (optical MOST Data Bus - they are routed inside a fairly still convoluted tubing) in the left hand foot well had been disturbed. Reconnecting it solved the issue. A word of warning! Do not bend too much as they are easily damaged and the data signal will not transmit correctly if they are damaged. I first had issues with this 2 years ago and once resolved it was fine until I lost my USB source (and Phone) while driving last week. I revisited the same connectors as last time but they seem fine. I've also inspected the optical connectors at the back of the head unit, that also appeared fine. I'm currently trying to find a location diagram of the MOST connections...
Old Feb 28, 2018 | 08:27 AM
Pootietang's Avatar
Pootietang
Did you finally resolve? Have the similar problem on my '07. Tuner and SAT icons gone, no radio or Sirius overnight.
thanks,
Pootie
Old Mar 17, 2018 | 03:19 AM
1973party's Avatar
1973party
thanks,
Pootie
Pooti, I didn't get this fixed and my cherished R56 MCS is poorly so it's going to be replaced pretty soon.
Good luck with sorting yours.
1973party
Old Nov 21, 2018 | 08:36 AM
JawKnee's Avatar
JawKnee
Hi, can you please describe in more detail, show, and/ or circle in a picture where exactly where you found the loose connection? Like the “convoluted tubing” you said.
By left hand foot well do you mean the passenger side (battery side) or driver’s side of an R56?
Thank you
Old Nov 22, 2018 | 02:32 AM
1973party's Avatar
1973party
Thank you
Hi JawKnee, my old R56 was a UK RHD car and the loose connection was in the LH (passenger) footwell. I no longer have the car, got an F54 clubman cooper S now so I can't take any pictures. The connector was to the side of the glove box, I can't recall having to remove any trim panels to gain access or if I was just a 'upside down job' in the footwell. I've had a quick look on google images but couldn't find any pictures. Good luck.
Old May 9, 2019 | 05:47 AM
Sue Jackson's Avatar
Sue Jackson
mcs 09 r56
I have lost my handsfree phone, aux and usb - nothing works and not showing on dash either, it did before. Stereo is ok, steering wheel buttons work. Nothing else, have checked Bluetooth module under passenger seat, we have power - any help peeps? I can see before that people have put the same but is there any results?
Old Aug 9, 2019 | 03:31 AM
Tilleynj's Avatar
Tilleynj
Thank you
JawKnee -- did you ever find it? Help me out with some pics if you did and save me some time??
Old Jan 6, 2021 | 01:52 PM
Martin Hoffmann's Avatar
Martin Hoffmann
Did anyone solve this? This is my exact issue....
