R58 JCW Coupe pic request - side stripes
Old Dec 21, 2012 | 01:01 PM
Black Sharpie's Avatar
Black Sharpie
Im trying to decide on JCW side stripes for my coupe. It is the black/red color scheme.
Does any one have a shot of the oem JCW side stripes on the coupe? Ive seen the red stripes on the white coupe, but thats it.
Black
Old Dec 23, 2012 | 02:03 AM
MarinePMI's Avatar
MarinePMI
I know there's one or two on the FB Coupe Owner's page...
Old Dec 23, 2012 | 07:09 AM
randers51's Avatar
randers51
I posted a pic on Facebook of my Black and red JCW Coupe with the side stripes. You can see it here:
https://www.northamericanmotoring.co...m/DSC_0363.JPG
Old Dec 23, 2012 | 01:04 PM
Black Sharpie
ah thank you very much! I think it looks great.
I wonder how much Mini installs them for. I am trying to get the red side stripes and extended the dual strips down to the front and back bumper. They are closed tho now
Old Dec 25, 2012 | 11:25 AM
Marioalex24's Avatar
Marioalex24
They look good on the black.
Old Dec 26, 2012 | 06:19 AM
MarinePMI's Avatar
MarinePMI
I think my dealer quoted something like $160, installed. I'd have to dig up the e-mail to confirm though....
Old Dec 26, 2012 | 07:32 AM
Black Sharpie
Really? I hope I can get that same figure, I am expecting a ridiculous install fee.
Old Dec 26, 2012 | 08:29 AM
randers51's Avatar
randers51
I had them installed for $160 also. Not too bad.
Old Dec 26, 2012 | 08:31 AM
Black Sharpie
Was it at a mini? I just called - not sure if they understood which stripes I was talking about, but they said $240 to install the stripes. :(
Old Dec 26, 2012 | 03:54 PM
randers51's Avatar
randers51
I just looked at my receipt and the cost was $260 not $160. My bad. I had some MINI Visa bucks to use with it so out of pocket was around $160. It was at the local dealership in Denver.
Old Feb 14, 2013 | 03:24 PM
latexsalesman's Avatar
latexsalesman
Did you buy the stripes from the dealer? My dealer has not seen your side stripes before, and I want to get them for my black coupe too!!
Old Feb 15, 2013 | 08:39 AM
If you are looking for the JCW side stripes:
OEM part number: 51142232633 Black, 51142232635 Red, 51142232634 silver.
Red looks good on black and silver.
Click the photo above for the items.
Thanks and let me know is you guys need anything else.
Old Feb 15, 2013 | 11:15 AM
is grumpy's Avatar
is grumpy
I have a Lightening Blue with Silver roof, anyone have a picture of that combo with the Silver side stripes?
Old Feb 15, 2013 | 11:55 AM
is grumpy - LB with silver side stripes and silver roof - could not find a shot but a great combo.
https://www.northamericanmotoring.co...group-151.html
I don't think you could go wrong as long as there is contrast and a right color.
Old Feb 15, 2013 | 02:01 PM
is grumpy's Avatar
is grumpy
I think you are right. I would have to see the silver though, to see how close it is to my existing silver stripes.
Old Feb 15, 2013 | 02:17 PM
That's what it looks like on black. The silver looks to be light silver.
Old Jun 29, 2016 | 12:00 PM
Just wanted to let you know the JCW silver are in stock and on super discount: 51142232634
https://www.northamericanmotoring.co...e-stripes.html
Old Jul 6, 2016 | 06:50 AM
Still have some in stock.
Old Aug 26, 2016 | 10:51 PM
adcam's Avatar
adcam
I just received my silver stripes from ECS. IS there a good video on how to install. I searched youtube but couldn't find a good one that explained how.
Old Aug 31, 2016 | 01:24 PM
I could not find install documents, but its line up with painter tap. Spry water on a back side after you peal a corner away , then squeegee the water out. Then peal back the font tape.
Old Sep 6, 2016 | 09:43 PM
adcam's Avatar
adcam
I will be applying the stripes this weekend since local shops here are charging too much for installation. Just to clarify- So I line up with painters tape so it will be straight. Wet the back side of the stripe and apply to car. Squeegee out the water. Do I need to wait for it to dry to peel out the front tape?
Old Sep 7, 2016 | 03:01 AM
N2MINI's Avatar
N2MINI
Once you squeegee out the water as good as you can spray the masking with the same soapy solution and let it set a few minutes or so ( alittle longer won't hurt ) it will help loosen the masking and give the vinyl alittle time to adhere to the car to help make it easier to pull the masking off without it trying to pulling the vinyl off with it... Also pull the masking straight back at an angle to the vinyl so you can easily watch to make sure the vinyl is not peeling up with it and you can work a corner back down with your other hand if need be before the whole section has peeled up..
Old Sep 7, 2016 | 01:30 PM
+1 , give it a little time in the sun to dry before you peal the top paper off.
Old Sep 10, 2016 | 11:39 AM
adcam's Avatar
adcam
Installation was not too bad. After searching the web, I would add use isopropyl alcohol to clean the surface. Be sure the squeegee you buy is the hard tip rubber. The soft one was useless to remove bubbles. The aligning of the painters tape was the hardest part. So what I finally did was get the widest tape available and taped it from the bottom of the car sill do it would be straight. Just waiting now for it to dry before I remove front tape.
Old Sep 10, 2016 | 06:46 PM
adcam's Avatar
adcam
Best $36 spent!!! Some small bubblew which I removed with a pin.
