Pls HELP I'm stranded
Old Dec 11, 2012 | 06:37 PM
jmoser's Avatar
jmoser
O2 macs. Battery is dead and I can't get the trunk open-locks aren't working!
Old Dec 11, 2012 | 06:41 PM
MiniR53's Avatar
MiniR53
If you lift up the rear bench you'll see a white circle; pull it and the trunk will unlock.
Old Dec 11, 2012 | 06:43 PM
jmoser's Avatar
jmoser
I have a 50+# box of corn sitting on the lid, I was hoping there was another way. But at least now I know what to do.thanks!
Old Dec 11, 2012 | 06:45 PM
MiniR53's Avatar
MiniR53
Nope, if your battery is dead, there is no other way to open the trunk but to lift the rear seat and pull the trunk release. Good Luck!
Old Dec 11, 2012 | 06:49 PM
jmoser's Avatar
jmoser
I don't see it. Where
Old Dec 11, 2012 | 07:00 PM
MiniR53's Avatar
MiniR53
Lift the rear seat cushion and underneath that you should see a cord attached to a plastic loop, pull on it and that should be it.
Old Dec 11, 2012 | 07:03 PM
jmoser's Avatar
jmoser
Can't get the tub of corn out, it's more like 75+ lbs ( I lift 50# bags of horse feed so I know). The tub is too big to get out behind the drivers door. Good grief this is ridiculous.
It would be very dangerous to hook two sets of jumper cables together? I know... So how do I get to the white handle?
Good grief...
Old Dec 11, 2012 | 07:05 PM
Mib4840's Avatar
Mib4840
Try jumping the car from under the hood.
Old Dec 11, 2012 | 07:07 PM
MiniR53's Avatar
MiniR53
Why do you have 75lbs of corn in your back seat?!
Well you could always just try to squeeze your hand underneath the seat cushion and feel around for the pull release, should be somewhere near the center.
Old Dec 11, 2012 | 07:10 PM
MiniR53's Avatar
MiniR53
Do you see the cord in the middle of this picture, where the rear seats used to be?
That's what your looking for
Old Dec 11, 2012 | 07:12 PM
jmoser's Avatar
jmoser
Won't jump from the front, even with a tow truck. Help arrived and the box of corn is out, well mostly. I have the bottom seat pad off but it's clean as a whistle... No handle, rope or pull. The upper rear seats are up to get
The seat pad up. Where?
Old Dec 11, 2012 | 07:18 PM
MiniR53's Avatar
MiniR53
There should be a pull release just like this in your car, you don't have one?
Old Dec 11, 2012 | 07:22 PM
Mib4840's Avatar
Mib4840
Dumb question but now that you have the corn out can you just replace the battery from inside. I know it will be a pain.
jmoser's Avatar
jmoser
Under the seat is clean as a whistle. Nothing when I flip the upper seats, nothing behind. Really)? Maybe can find a tow truck with long enough cables...but hate to jup the battery with the hatch down. Maybe tow, remove the battery and charge it. I don't suppose Mini will help me if there list an escape...I've been locked inside with a dead battery, couldn't open it from inside or out. Done done done...thanks for responding so quickly!
Old Dec 11, 2012 | 07:24 PM
MiniR53's Avatar
MiniR53
I don't think that would work because that would require the backrests to be down. They aren't really accessible from inside the car.
Old Dec 11, 2012 | 07:25 PM
LTLMCPE's Avatar
LTLMCPE
The early 02's do not always have the hatch release. My 02 MCS did not which I also found out the hard way when my battery died.
Old Dec 11, 2012 | 08:45 PM
minsanity's Avatar
minsanity
^True that. The emergency boot release cable was an afterthought. Try asking dealership to hook 1 in now that you've been traumatized.
kvnadriano
Aug 10, 2015 08:48 AM
ghui
Detailing 101
Jul 1, 2010 11:57 AM
wheelspnr
Jul 9, 2005 07:15 AM
chrisw765
Apr 18, 2005 06:00 AM
