Airlock? What airlock?
Old Dec 11, 2012 | 11:35 AM
kennedy71809's Avatar
kennedy71809
So this morning on the way to work my heat wouldn't work in my 03 R50 Justa'. When I got a mile away from work I stopped at a stoplight and my temp gauge started climbing from its happy middle zone to the blinky red light danger zone...quick. As I accelerated away from the light it dropped back to the middle so I took the chance of another red light to make it to work. After doing some research here, mini2, and pelican parts, as well as a call to the ever helpful Way and Century MINI I figured out what happened. Apparently I have a coolant leak and didn't notice. The fluid in the overfill reservoir got to low and the coolant system sucked in air. Apparently this causes there to be a blockage and the coolant to boil. Still not sure why this cuts the heat out? So on my lunch break I managed to get the coolant system bled, filled, and back up and running again. For a beginning tinkerer I am proud of myself but couldn't have done it alone! Thanks to all who are willing to help newbies like me!
Old Dec 11, 2012 | 12:44 PM
ljmattox's Avatar
ljmattox
The air lock causes voids in the coolant, so at times none is flowing through the heater coils; thence, no heat.
I drove my old small-block Camaro quite a while, nursing a leaky water pump...I could tell when it was *really* getting low on coolant, when the heat started to go. :-)
Old Dec 11, 2012 | 01:19 PM
kennedy71809
Ahhh that makes sense! Thanks! I'm guessing that the leak is coming from the coolant overflow tank...
TonyB
Dec 15, 2014 12:01 AM
flipfury
Mar 11, 2014 03:16 AM
davemansmi
Feb 16, 2010 02:18 PM
OKMini
Classic Mini Talk
Aug 29, 2009 06:25 AM
kapps
Jun 20, 2007 03:22 PM
