General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
World's Fastest MINI Racer? Onboard At The Nürburgring
Old Dec 9, 2012 | 02:32 AM
Mab01uk's Avatar
Mab01uk
MINI Cooper Race Car by Schirra motoring: Onboard Nürburgring Nordschleife.
Love that sequential gearbox!
300Bhp@6250
410Nm@4400
The MINI Schirra race car
(Long range version)
In the last race of the Endurance Championship Schirra MINI caused a minor sensation:
First, 1.6-litre car below the magic limit of nine minutes for 24.369 kilometers on the Nürburgring (Grand Prix track + Nordschleife).
Specifications
Engine Water-cooled four-cylinder inline engine with turbocharger and direct fuel injection, two overhead camshafts, four valves per cylinder, bore times stroke (mm) 77.0 x 85.8, Engine 1598ccm, 10.0:1 compression
Power 300PS (221 ​​kW) at 6250/min, max. Torque 410Nm at 4400 rpm, power output per liter 187.7 hp / L
Power transfer front drive, sequential six-speed transmission (paddle shift), differential lock
Suspension Independent suspension all around, front wishbones, MacPherson struts, stabilizer bar, rear double wishbone, trailing arms, coil springs, shock absorbers, stabilizer
Brakes disc brakes all round, ventilated at front, diameter front / rear 330/280, four-piston front calipers, rear single-piston floating calipers, racing ABS
Tyres Michelin slicks and rain tyres on 9.0 inch rims 24/61/17
Body bodyshell MINI with welded cage, carbon bodywork components x (except roof section), wind tunnel modified front splitter, modified diffuser and wing, smooth underbody, Length Width x Height (mm) 3798 x 1712 x 1446 Wheelbase mm 2467, Front / rear track 1482 989kg / 1490, weight (including 20 litres of fuel), power to weight ratio 3.3 kg / hp
Performance
From 0-100km / h in 4.7 s
From 0-200km / h in 15.8 s
Top speed about 258km / h
dynamics
Short track Hockenheimring in 1.07,1 min
Nürburgring Nordschleife + GP course in 8:58 min
Old Dec 9, 2012 | 05:08 AM
S-Driver's Avatar
S-Driver
Sweet!
Old Dec 9, 2012 | 06:14 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Didn't the GPII do this course in 8:23 ?
Old Dec 9, 2012 | 11:37 AM
Mab01uk's Avatar
Mab01uk
I don't think the GPII did the Nurburgring + GP layout.
(bypassing the modern GP track)
See map:
http://en.wikipedia.org/wiki/File:Ci...gring-2002.svg
ludedude
Aug 10, 2015 07:16 PM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
marendt428
Aug 8, 2015 04:44 AM
