World's Fastest MINI Racer? Onboard At The Nürburgring
1 Attachment(s)
MINI Cooper Race Car by Schirra motoring: Onboard Nürburgring Nordschleife.
Love that sequential gearbox! :thumbsup: 300Bhp@6250 410Nm@4400 The MINI Schirra race car (Long range version) In the last race of the Endurance Championship Schirra MINI caused a minor sensation: First, 1.6-litre car below the magic limit of nine minutes for 24.369 kilometers on the Nürburgring (Grand Prix track + Nordschleife). Specifications Engine Water-cooled four-cylinder inline engine with turbocharger and direct fuel injection, two overhead camshafts, four valves per cylinder, bore times stroke (mm) 77.0 x 85.8, Engine 1598ccm, 10.0:1 compression Power 300PS (221 kW) at 6250/min, max. Torque 410Nm at 4400 rpm, power output per liter 187.7 hp / L Power transfer front drive, sequential six-speed transmission (paddle shift), differential lock Suspension Independent suspension all around, front wishbones, MacPherson struts, stabilizer bar, rear double wishbone, trailing arms, coil springs, shock absorbers, stabilizer Brakes disc brakes all round, ventilated at front, diameter front / rear 330/280, four-piston front calipers, rear single-piston floating calipers, racing ABS Tyres Michelin slicks and rain tyres on 9.0 inch rims 24/61/17 Body bodyshell MINI with welded cage, carbon bodywork components x (except roof section), wind tunnel modified front splitter, modified diffuser and wing, smooth underbody, Length Width x Height (mm) 3798 x 1712 x 1446 Wheelbase mm 2467, Front / rear track 1482 989kg / 1490, weight (including 20 litres of fuel), power to weight ratio 3.3 kg / hp Performance From 0-100km / h in 4.7 s From 0-200km / h in 15.8 s Top speed about 258km / h dynamics Short track Hockenheimring in 1.07,1 min Nürburgring Nordschleife + GP course in 8:58 min Attachment 161346 |
Sweet!
Nürburgring Nordschleife + GP course in 8:58 min |
Originally Posted by -=gRay rAvEn=-
(Post 3638914)
Didn't the GPII do this course in 8:23 ?
(bypassing the modern GP track) See map: http://en.wikipedia.org/wiki/File:Ci...gring-2002.svg |
| All times are GMT -7. The time now is 01:24 PM. |
