R50/53 Shift Knob-Arghhhhhh!!
Old Dec 8, 2012 | 10:15 AM
safeharbor's Avatar
safeharbor
Shift ****-Arghhhhhh!!
I tried and tried, but cannot pull off the bloody shift **** for replacement! Is there a tool or method that can help??!!
Old Dec 8, 2012 | 10:23 AM
Mib4840's Avatar
Mib4840
You might want to try getting a "fork" that will fit around the shifter shaft and put it under the **** and then use a rubber hammer to pound up on the "fork".
Old Dec 8, 2012 | 10:53 AM
JAB 67's Avatar
JAB 67
I recall that the technique involves leaning over the **** so that it points toward your chest, not your face. Then pull with both hands.
Old Dec 8, 2012 | 11:43 AM
RedAndBlackMiniS's Avatar
RedAndBlackMiniS
I remember had some trouble getting mine off... I had to mount myself with one leg in the driver's footwell and one leg in the passenger footwell, grasp the shift **** and pull with all my strength... just be sure no one is around to see you when you do this, for the sake of not scarring them for the rest of their life!
Old Dec 8, 2012 | 01:18 PM
Capt_bj's Avatar
Capt_bj
that's the truth
no secret and no tool
just a straight pull
ASSUMING what you have now is a stock OEM one . . .
Old Dec 8, 2012 | 04:06 PM
safeharbor's Avatar
safeharbor
It is not a stock one. Was thinking of using vice grips on the **** shaft, and a hammer to the vice grips. Hope the previous owner did not use adhesive of any kind!
Old Dec 8, 2012 | 04:40 PM
Capt_bj's Avatar
Capt_bj
ALL BETS OFF
unless it is a Whalen - can't help you
it could be on there with JB Weld in which case you could pull the entire engine into the pass' compartment!
sorry dude but you're screwed
if you want to replace the ****, you may well end up replacing the entire shifter . . .
Old Dec 8, 2012 | 05:20 PM
safeharbor's Avatar
safeharbor
Understood. I actually want to replace it WITH a Whalen! Will see how it goes...
Old Dec 8, 2012 | 05:22 PM
yetti96's Avatar
yetti96
Check for a trim ring that will unscrew and reveal a set screw, that is what on my R50 when I bought it used.
Old Dec 8, 2012 | 05:26 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
How about some pics of it. May shed some light.
Old Dec 8, 2012 | 06:09 PM
safeharbor's Avatar
safeharbor
Here it is. It is a special **** with a light switch in it. Top comes off, but didn't see a set screw...
Old Dec 8, 2012 | 06:10 PM
safeharbor's Avatar
safeharbor
Shoot! Thought I attached a picture...
Old Dec 8, 2012 | 06:13 PM
safeharbor's Avatar
safeharbor
Maybe this will work!!
Old Dec 8, 2012 | 06:24 PM
Kahnfucious's Avatar
Kahnfucious
Have no idea but what about all those hex screws on top? Did you try loosening those?
Old Dec 8, 2012 | 06:36 PM
safeharbor's Avatar
safeharbor
They secure the top, but don't seem to have anything to do with securing the ****.
Old Dec 8, 2012 | 06:44 PM
Mib4840's Avatar
Mib4840
If you can find a name brand on the ****, Google it and see how the instructions say to mount it. If no name, Google shift **** lit or light or??? Look in the Image tab until you locate one that looks like yours.
Old Dec 8, 2012 | 06:45 PM
Mib4840's Avatar
Mib4840
I have seen this **** before and it seems like it was on EBay.
Old Dec 8, 2012 | 06:56 PM
Redhatch's Avatar
Redhatch
This **** is on ebay. You should be able to unscrew the lower collar and remove the setscrews holding the **** on. Unless it is glued on.
Old Dec 8, 2012 | 07:27 PM
Mark97xp's Avatar
Mark97xp
I can see why your trying to remove it. That thing is horrid looking.
Old Dec 8, 2012 | 08:24 PM
safeharbor's Avatar
safeharbor
LOL-Yes, it is not pretty! Will give it another shot tomorrow. I found it on the web, but no instructions. Thanks for all of the comments!
Old Dec 8, 2012 | 08:48 PM
submitaweasel's Avatar
submitaweasel
I figured this thread was about the stocker. I can't believe how hard mine was on. I literally could not get it off no matter how hard I tried. 1 hour banging with a hammer...an hour or so straddling it pulling with all my might (and I am in no way a weak person) and ended up using a hacksaw to the lever thanks to having a replacement on hand and no other options. Ridiculous.
Old Dec 8, 2012 | 08:59 PM
Redhatch's Avatar
Redhatch
There are instructions on the ebay listing.
Old Dec 8, 2012 | 09:49 PM
BMBULBE's Avatar
BMBULBE
Try and develop an alternative: Call your local dealer and ask what they'd charge. I doubt it would take much time for someone who'd done it before.
Think of it as ordering something in a restaurant because it's too much of a hassle to prepare it at home!
Old Dec 8, 2012 | 09:51 PM
ROOSEY's Avatar
ROOSEY
that definitely looks like one of the screw/thread on types. I'm almost 100% positive they only come in screw on from working at autozone where they also sold these...i have a really bad gut feeling that someone glued it on
Old Dec 9, 2012 | 06:37 AM
safeharbor's Avatar
safeharbor
Looks like you are right-the base cover must screw down to hide a set screw. I will try to get it off later today. Cross your fingers! Thanks Again.
