R59 0-60 track times?
Old Dec 7, 2012 | 08:42 PM
TheZlog's Avatar
TheZlog
0-60 track times?
Has anyone taken their JCW or S to test their stuff, or has a reviewer done a semi-decent test of what the 0-60 is for the Roadster S or the JCW?
I thought I read somewhere that the Roadster's got *slightly* faster times than the hard tops due to less weight and slightly better aerodynamics. Am I dreaming this up? I can't seem to figure out where I got the idea from.
Old Dec 7, 2012 | 10:30 PM
hsautocrosser's Avatar
hsautocrosser
When MINI released 0-60 times it was Coupe, Hardtop, then Roadster. The Roadster weighs the most.
Old Dec 8, 2012 | 05:19 AM
Julien321's Avatar
Julien321
Originally Posted by TheZlog
...hard tops due to less weight and slightly better aerodynamics....
In almost all (if not every) case the convertible (soft top) version = more wight, worse aerodynamics and lower performance figures than the hardtop version.
Old Dec 9, 2012 | 10:04 AM
grantsfo's Avatar
grantsfo
Anyone notice that final gear ratio for both s coupe and s roadster are differnt than the s hardtop ? s Coupe and s roadster use same final ratio as JCW hardtop.
With roadster being 90 lbs heavier than hardtop I'd expect it to be about .1 slower in 0 to 60. But if gearing is slightly different that might change things.
Old Dec 9, 2012 | 11:13 AM
Gil-galad's Avatar
Gil-galad
IMHO, the 0-60 time differences are largely irrelevant. Acceleration from a standing start is not what a MINI was designed to excel at.
Of course, snaking through the twisties is a completely different matter...
Old Dec 9, 2012 | 01:20 PM
TheZlog's Avatar
TheZlog
Weird, not sure where I heard that they were lighter, but 90lbs isn't too bad.
The Roadster is more aerodynamic than the hardtop, isn't it? That is what I was referring to.
Old Dec 10, 2012 | 04:48 AM
Julien321's Avatar
Julien321
If by aerodynamic you mean drag coefficient (the most common quoted but only one of many measurements) then yes technically. The windshield rake angle gives the Roadster (and Coupé) a slight advantage in frontal area (not enough to significantly influence 0-60 or 1/4 mile times or overcome 90lbs) but the Hardtop does have a VERY large downforce advantage. 90lbs doesn't mean as much in a Mustang Shelby GT-500 but 90lbs in a MINI JCW's = almost 1/2 pound added per horsepower which is significant.
Drag coefficient and CDA (coefficient rattings x frontal area) for JCW models:
Hardtop: 37 - 74
Roadster: 36 - 72
Coupé: 35 - 69
Of course the Coupé is more aerodynamic than the Roadster and a more direct comparison (since both share the same windshield rake).
Old Dec 10, 2012 | 08:07 AM
ignitionmodule's Avatar
ignitionmodule
Ever notice how you can ask a perfectly reasonable question and get a lot of posts that have no answers at all?
Motor Trend was able to squeeze the fastest 0-60 time out of the JCW Clubman at 5.7 seconds.
http://www.motortrend.com/roadtests/...l/viewall.html
Old Dec 11, 2012 | 06:37 PM
roadsterman's Avatar
roadsterman
Hardtop: 37 - 74
Roadster: 36 - 72
Coupé: 35 - 69
And then there is the top up vs top down issue. My roadster gets worse highway mileage with the top down. I believe the wing drag is causing some of this but I can't stand the stupid warning chimes long enough (when I disconnect the motor) to test the theory...
W0TM8
Dec 19, 2019 07:50 AM
theblackfalcon
Oct 11, 2015 09:49 AM
bjcarter2
Aug 31, 2015 04:03 PM
Dashdog
Aug 10, 2015 06:17 AM
