Will 05 S wheels fit 08 hardtop
Old Dec 6, 2012 | 04:05 AM
PaulK's Avatar
PaulK
Will 2005 S Hardtop OE wheels fit a 2008 hardtop? The tire size on the 2005 are 195/50r16 and on the 2008 they are 175/65r15. I understand the 2008 has an optional size 16" radius.
Old Dec 6, 2012 | 04:08 AM
yetti96's Avatar
yetti96
Yes. All MINIs to date have the same bolt pattern with the exception of the Countryman (R60). The bolt size did change however from a M12 to a M14 but the hole on the OEM wheel should still be big enough to allow fitment on any year car ('02+).
The different in wheel size isn't really important so long as you are not trying to put a 15" wheel on a S model as the brakes are too big for the wheel to fit. With regards to size, the overall diameter is what is more critical when changing wheels and tires. The different between those two you listed is about 1.17% this is negligible because every tire manufacture is slightly different and the size will change that much or more through the wearing of the tread. To me, 3% is enough difference to where you might begin to notice the speedo being slightly different.
Old Dec 6, 2012 | 05:05 AM
PaulK's Avatar
PaulK
yetti96,
Thanks for the quick reply. Very informative. I knew the bolt pattern would fit but I wasn't sure about the rest. I thought I might have a problem turning and rubbing. Really appreciate your help.
Old Dec 8, 2012 | 06:43 AM
ricbow's Avatar
ricbow
First gen have 12 mm bolt holes, second gen have 14 mm holes . First gen wheels won't fit 2 gen with out mods
Old Dec 8, 2012 | 06:54 AM
oldtruckpainter's Avatar
oldtruckpainter
The stud sizes have changed, that is true. But the bolt holes in the wheels are all the same size. also the taper the coned part of the bolt head fits into is the same. I am running wheels from a 2002 1st gen on my 2010 R56 (2nd gen) with no changes at all. I even can use my stock 14 mm wheel bolts.
Old Dec 8, 2012 | 06:57 AM
oldtruckpainter
Forgot to mention that the 1st gen wheels I'm using are my winter wheels. Not the bridgespokes listed in my signature.
Old Dec 8, 2012 | 10:58 AM
rkw's Avatar
rkw
It will fit fine. All MINI OEM wheels (all years, both generations) have large lug holes that can fit 14mm diameter lugs.
Old Dec 8, 2012 | 11:40 AM
RedAndBlackMiniS's Avatar
RedAndBlackMiniS
They will fit great with no problems.
reverse01134
Jan 16, 2017 06:37 AM
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
FrostyFox
Aug 12, 2015 02:33 PM
