R56 how often do you change transmission fluid for justa?
Old Dec 1, 2012 | 02:42 PM
yyj3869's Avatar
yyj3869
I just hit 74k automatic trans and never changed transmission fluid..
when did you guys change them?
Old Dec 1, 2012 | 03:30 PM
mini4mo's Avatar
mini4mo
Not that easy to do from reading here.
Old Dec 1, 2012 | 07:18 PM
countryboyshane's Avatar
countryboyshane
I can't comment on Aisin equipped MINIs specifically, but traditionally manufacturers specify between 80,000-100,000 miles to exchange transmission fluid. If you're in the mood to change it now you're certainly not going to hurt anything.
Old Dec 3, 2012 | 05:59 AM
condor27596's Avatar
condor27596
There are a lot of threads on this. I am currently working out a "new" method.
You should get the tool www.nxtools.com I think I do not have it bookmarked here.
I did not have good luck filling from the top, but it is easy from the bottom.
I did not get enough in it this past weekend. So tonight instead of jacking it up (a major pita) I am going to take the tire off and see if I can go from there.
Old Dec 3, 2012 | 05:02 PM
tjkenny15's Avatar
tjkenny15
FIRST POST! I've actually been wondering thing. I have a 6-speed auto with 52,000 miles and think the shifts could be smoother. Any thoughts? Cost from mini to do a filter/flush??
Old Dec 3, 2012 | 07:29 PM
bmwr606's Avatar
bmwr606
my friend owns a transmission shop
he overhauls both manuals and automatics
he says ALL transmissions should have fluid changes every 30,000 miles
my 1997 gmc sonoma manual has 288,000 miles, has had fluid changes every 30,000 (including the front and rear differentials and transfer case) and i have had zero problems ... it still shifts as good as new
i will be doing the same on my cms all4
oil is much cheaper than transmission work
scott
Old Dec 5, 2012 | 10:13 AM
strobeyprobey's Avatar
strobeyprobey
I am changing out the pan fluid every 10k miles (since I hit 50k), so basically every oil change).
sprp85
Aug 22, 2015 06:16 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
FLYM1N1
Aug 16, 2015 01:17 PM
