R50/53 Weird boost numbers
Old Nov 30, 2012 | 05:47 AM
apardan's Avatar
apardan
Weird boost numbers
Greetings there,
I have a 2006 mcs ( 16+2 , grs cooler, alta cai, one ball, wossner pistons)
I see a problem with my boost readings. The boost numbers are increasing until 6.400 rpm to 1.10bar and then decreasing to 1 bar till close to the reds.. Is that normal i mean i was used to the boost constantly increasing.. What should i check? Map sensors maybe?
Thanks a lot for any help!
George
Old Nov 30, 2012 | 06:08 AM
submitaweasel's Avatar
submitaweasel
Sounds like a boost leak or belt slipping. IC couplers are known to fail...belt tensioner is known to fail...belts stretch. First thig I'd do is take a look at your tensioner and see how many holes are visible.
Old Nov 30, 2012 | 07:48 AM
apardan's Avatar
apardan
Thanks a lot for the quick reply! By belt tensioner you meann the thing that stretches the pulley belt?
Old Nov 30, 2012 | 08:33 AM
submitaweasel
Yup. Thats the tensioner.
Sc00terbum
Sep 11, 2015 07:17 AM
mbatech
Sep 10, 2015 03:40 PM
Filmy
Sep 7, 2015 11:27 AM
Sep 2, 2015 11:15 AM
