rust on spark plug walls help
Old Nov 29, 2012 | 04:48 PM
2003minicooper's Avatar
2003minicooper
So every now and then 1-2 months or a little longer go by, and my car starts shaking, and won't gain much speed for a couple minutes, check engine light comes on for cylinder 3 misfire. New spark plugs, coil pack, wires, ect. I bought a compression test kit today, was going to use it until I pulled the wires out of all cylinders. All have rust on the spark plug walls except the 1st cylinder. I found a way to clean the rust off.
Should I do a compression test still?
Old Nov 29, 2012 | 04:53 PM
bmwr606's Avatar
bmwr606
is your car losing coolant? an internal head gasket leak letting coolant into the cylinders could be the cause
scott
Old Nov 29, 2012 | 04:58 PM
2003minicooper
No, coolant is good. Oil is also good. This is the first car I've owned that doesn't seem to burn much oil. When I do my oil change I get very close to 5 quarts back out of it.
Old Nov 29, 2012 | 05:07 PM
Tio Barry's Avatar
Tio Barry
What year car do you have? 2003 is first gen
Old Nov 29, 2012 | 05:08 PM
submitaweasel's Avatar
submitaweasel
5 quarts is a tad too much I believe. Maybe not. My mind pushes info out quickly and the last time I changed my oil was about 3k ago and I don't log many miles. (06 with 48k)
Where do you live? Possibly a humid climate causing this?
Old Nov 29, 2012 | 05:13 PM
2003minicooper
I always use a 5 quart jug, and check my oil which is at the full mark on the dipstick after adding 5 quarts. 2003 base, I live in Pennsylvania, and its currently like 30 degrees farenheight so could enough to snow.
Old Nov 29, 2012 | 05:28 PM
submitaweasel
Well everything I could think of is ruled out. Hopefully someone can chime in with some insight.
Old Nov 29, 2012 | 05:36 PM
2003minicooper
ok, thanks.
Old Nov 29, 2012 | 05:38 PM
submitaweasel
You can thank me for nothing except the bump
Old Nov 30, 2012 | 04:41 PM
Slave to Felines's Avatar
Slave to Felines
You should post in the 1st-gen section; you might get people who know your car better over there.
eliseo1981
May 10, 2016 05:19 AM
JMF1975
Sep 11, 2015 03:29 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 4, 2015 03:56 PM
Sep 2, 2015 09:05 AM
